ive got a EMS dual sport with hand controller
it came out of my r32 running rb20 with around 215kw at the treads.
it doesnt have wiring loom but you can get them for $100 or you can come pull the one out of my car!
to run EMS you dont need air flow metres!!
it just uses a small sensor that you tap into the pipe just before throttle body.
SOLD
im in sydney/blue mountains
https://www.sau.com.au/forums/topic/125377-ems-ecu/
im getting rid of it because a good mate can get me and tune a microtech for a really good price and dyno time will cost me next to nothing with him.
i would keep the EMS but he only knows how to tune microtech.
well some of the EMS spec are:
injector outputs-8 it can run max-16
ignition outputs-4 it can run max-16
fuel maps-26
ignition maps-26
total fuel points-78
total ignition points-78
auxiliary inputs-1
auxiliary outputs-4
it has data logging/ nitrous management/vtec(YO)control/boost control/anti-lag
and is pc and handset programmable.
also the fuel correction maps/factors are:coolant temp,air temp,full throttle,closed throttle,fuel trim,curve modifier,barometric pressure,variable injection resolution,prediction algorithm.
if there is anything elso you need to know just let me know!
https://www.sau.com.au/forums/topic/125377-ems-ecu/#findComment-2320573
i had this on rb20 with only fmic and t3/4 high flowed turbo which is off vl commodore and a exhaust and made 215kw.
everything else was stock.
in my opinion this is a top ecu for the price.
Azzr,
what model is it - Stinger _ 8860 ? How many bar is the map sensors - up to 2.8 or up to 5?
https://www.sau.com.au/forums/topic/125377-ems-ecu/#findComment-2321642
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
