So, does it shit you when the post is worthless?
As an aside there is an interesting series of articles in the present edition of RACETECH magazine about locating roll centres and about how to work out the maths that go along with it. Current issue has a Renault F1 on the cover.
Has anyone measured up the lengths of the links? I will get around to doing this oneday, just not today as my car is in the shop...
so do you need to post in the thread to subscribe? i've never subscribed to a thread before. or were you just letting us know?
In the "fast reply" box down the bottom you type something then click the little box under it that says "Email notification" ;)
How does one actually correct bump steer? My car gets massive amounts of this, probably due to the crazy JDM tyte y0! suspension that's in it.
First off, let's make sure we are talking about the same thing.
True bump steer means the toe angles change as the wheels go up and down, like when one, or both of them, hits a bump. True bump steer is usually caused by excessive lowering, which changes the angles between the lower control arms and the steering arms. When the car hits the bump, the wheels toe in or out without any movement of the steering wheel. This can be front wheel and/or rear wheel (if the car has IRS).
To correct this, the easiest method is to return it to a more sensible height, around 355mm front and 345 mm rear for R32/33/34. Alternatively you can purchase bump steer correction kits, which require considerable skill and experience (not to mention equipment) to set up so as to eliminate the toe changes
Bump steer is NOT the car being thrown off line when it hits bumps. That's usually caused by excessive spring and/or shock rates. Occasionally it is caused by worn/damaged shocks and/or inappropriate shock rates for those springs ie; lowered springs and 100,000 k's old standard shocks.
To correct this, the first step is to return it to a more sensible height, around 355mm front and 345 mm rear for R32/33/34. If that doesn’t fix it, then you need to look at the spring and shock condition, plus their rates.
Hope that was of some help
:mellow: cheers :rofl:
ok cool. instead of re-inventing the wheel im gonna return the arms back to standard angles
and adjust the front tie rods acordinly.(for bump steer corection)
coz yeah its really pointless DJR81.
do you have any idea ayt all what im talking about? or why i might be wanting to do this adjustment?
Well, as it happens, yes. It just worries me that the questions you are asking betray a lack of a firm understanding on your behalf as to what you need to do to achieve well, you haven't really stated that clearly. Changng the length of the links in the suspension is dead easy (It is common practice to change all the upper link lengths as well as the caster rods). Relocating pick up points, be they on the chassis or on the hubs is a completely different kettle of fish. Only when you have developed (ie drawn) all the geometry, calculated the roll centres and plotted the centre of gravity relative to the roll centres can you be in any position to make a first pass estimate of any changes you may require
I never did say it was pointless, but it is difficult & not the sort of thing to play around with on a whim.
Anyway, as has been said previously, it's nice to be nice. So all the best with your mods.
The big problem I find with changing roll centres (something we used to do on the V8 SuperCars as infrequently as possible) is that it changes EVERYTHING else. The springs rates that worked OK before, no longer are right, ditto the damper setting, anti roll, camber settings, ride height, toe alignment etc etc.
So, the setup information that you have developed over the years, becomes compromised because of the change in roll centres. All of the “factory” set up information becomes useless. Basically you have to start all over again on your development path, gather a whole new set of information. You can’t share this information with the guy next to you, unless he is running the same roll centres as you.
Now this is all very well when you have 2 cars and 20+ guys in the race team and plenty of time (money) to do the necessary testing. Not to mention the skills base necessary to interpret the results and the logging equipment to gather the data in the first place.
If what you are seeking is improved lap times, then there are much better ways to achieve it than changing the factory roll centres. Keeping in mind that Nissan always had Group A competition in mind when they built the R32GTR. Unlike many other cars, the factory roll centres are not terrible.
:woot: cheers ;)
The other thing is that changing the roll centre on a Watts linked live axle is dead easy. Changing it on a double wishbone suspension is much harder as it breeds other, more subtle changes to the set ups.
From memory the Group A regs allowed you to move pickup points by a nominal amount. Not sure what the regs said in reference to the arm lengths.
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
