Hey guys and girls :D
Just wondering if anyone has pics of their, or anyone elses R34 Gtt's engine bay with FMIC cooler pipes installed. I'm getting mine done next week and i'm just wondering about the stock air box and air intake pipe. I am guesing they are no longer usable due to the pipes being too big and thus the air intake pipe being unsuable, which in turn stops the airbox getting an air feed. So i am thinking i will have to go for a pod with a head sheild or something, but thought perhaps someone had found a way to use the stock air box.
I'm after pics of either of these set ups, FMIC pipes and still using the airbox (and perhaps the air feed), or with a pod filter set up (with a heat sheild/box, or however you have done it).
Sean
https://www.sau.com.au/forums/topic/125379-engine-bay-pic-of-r34s-with-fmic/
i think satanic has a pic of a 34 with the fmic pipe going around the neo cover and the stock air feed. what you'll need to do is modify the air feed that goes to your airbox to go around the piping (by chopping about 2 inches from it). depending on the kit the neo cover needs to be sliced a little too.. but it's not too noticable.
someone on sau has posted a stagea with the piping all nice a neat in the engine bay.. it should be the same for the 34.
:P Just trying to help you out buddy.
But I'd think long and hard about it, as you'll save yourself a whole deal of trouble, unless you're aiming for say 300+RWKW i can't see the point. All you'll probably do is introduce reduced throttle response. Plus you can get your extra pipes when you rip out the air-box.
However, I realise not all mods are done for purely logically reasons, if you've got your heart set on shiney new pipes thats ok too. :D But just so long as you're aware of the situation.
yeah ive got pics of a r34 install. used a blitz intercooler. just look in my gallery. imho, thats the best bet cause cross over pipe = headache fabrication to the structure of the car/pipes itself. let me know if you need any help etc etc
search forums, there is a thread on the use/benefits (if any) of pvc as intercooler piping that goes on for pages and pages.
that nots not what your asking, if your doing custom fabrication then what the issue? hence 'custom'
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
