Hey guys, please leave this thread in the forced induction section, because it relates to fabricating for a turbo install, so I'm after advice from other guys who have done something similar.
Basically, I need to bend this piece of metal. What is the best way to do it without snapping it?
It's about 2 cm thick. If I just hammered it with a sledge hammer, i think it would snap.
https://www.sau.com.au/forums/topic/125386-bending-metal/
as rstme said, get the oxy out and heat it up. then as you are heating have someone hitting it with a hammer. and you have to also hit it a bit where it is (right on the bend) to make sure it isn't brittle.
or, depending on how strong it has to be, you could just cut it and weld it. if it is welded with a mig it should be pretty strong.
https://www.sau.com.au/forums/topic/125386-bending-metal/#findComment-2315944
When you say 2cm think, do you actually mean thickness or width?
I have no idea what you would need 20mm thick steel for on a turbo setup, unless it's for flanges, spacer plates, or your making some brackets to hold a turbine off a 747? :D
If it is infact 20mm thick, as said previously, cut and weld. If it's only a few millimetres thick, either put it in a vice and hit with hammer, or take it down to a fabrication shop and get them to press bend it to required angle. Would cost you next to nothing to have it bent. Infact if they charged you, imo their tightasses ;)
https://www.sau.com.au/forums/topic/125386-bending-metal/#findComment-2315980
Ok, sorry for the confusion guys. Basically, iv'e mixed up 2 questions.
1. I'm installing a turbo and some of the brackets have problems clearing. The steel is about 5mm thick? I can't bend it with my hands. Never really thought about heating it, but I don't have an oxy torch.
2. I'm also wondering whether it's possible to bend a strut brace. Comes form an r32 and fouls slightly on the heatpad. I want to straigihten out the bends so it sits lower.
https://www.sau.com.au/forums/topic/125386-bending-metal/#findComment-2316340
5mm will bend with a helper, like a shifter, or if you want a fold line use 2 bits of flat each side with 2 shifters, if you want a deeper bend than that, a hammer and dolly (slightly curved block) or a vice.
Strutt braces by nature should be hard to bend, mines hollow and would be difficult to bend without a crease, a pipe bender may do it if the profile is right.
https://www.sau.com.au/forums/topic/125386-bending-metal/#findComment-2318623
5mm thick steel will be hard to bend by hand, i used to work with aluminium and i know from off the top of my head that steel is about 3 times as strong. Probably better off taking it somwhere and giving them a 6 pack of beers to bend it up for ya, at least that way the bend will be straight and be able to get the perfect angle you wish to achieve
https://www.sau.com.au/forums/topic/125386-bending-metal/#findComment-2318751
    • My purchase experience was no where near as glorious as yours but still a significant moment in my life! Yeah that's a bit of a dilemma as to whether you bring it back or not!  Obviously a massive waste of time and effort to bring it back if you're only going to move there anyway!
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
