Hi everyone,
Bought a trust oil cooler with thermo. and relocation kit for a gtr33
On the side of the box it has ecn32 as a stock code.
Has the supplier gave me the wrong one?
Gave it to a reputable mob in Campbellfield ,who said ther was no room to fit it at the front right
I said i had never seen a GTR with it there ,always seen it at the front left.
I was then told the hose was to short for that.
Anyway after speaking to the supplier,was told the guys who tried fitting it were hopeless, and that the
oil- lines had to go under the engine(Tight fit).
Anyone know who can fit this for me.......desperate to install.
Thanks ;)
Edited by 700HP-GTR33
https://www.sau.com.au/forums/topic/125393-oil-coolershelp-needed/
depends which one you have, most Trust cooler will fit between the radiator and intercooler, and some other ones will fit on the drivers side guard.
Only the HKS ones will fit on the passenger side.
whats the part no.
im sure we can fit it for, maybe might need longer hoses.
whats the part no.
I dont have the cooler with me at the moment.
It is at work, but will post up the part no. tommorrow ;)
Thanks for the reply
The trust cooler that fits BCNR33 is mounted on the driver's side. In saying that they do not allow fitment with stock blow off valves, they are designed for cars with Trust Type-R single blowoff valve..
I know this as I tried fitting it and realised there is no room for both stock blow off valves and oil cooler core. The instructions also show a pic of a trust type-r blowoff valve in place of the stock ones...
Basically you will have to get it modified and custom fitted to retain standard blowoff valves, definetly go see Ray (SXR), he'll be able to sort it out for you....
It is at work, but will post up the part no. tommorrow :)
Ok then.....yippi for Italy :D
The code...hand written for the cooler reads........S.BNR32-10IF
No instructions found in the box
Ok then.....yippi for Italy :)
From that code you have given its obviously for a R32GTR, is it a 10 row oil cooler?? If it is then it should be mounted behind the radiator.. It should be a 16 row oil cooler to be side mounted.. You should also been supplied with brackets and air deflectors if it is a side mount....
Either way it can be modified to fit your car.....
ok then
It comes with brackets and a plastic hose...is this the deflector.
It is a 9 core and comes with side mount bracket aswell
Ill call sxr today...for a price plus oil change
Thank
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
