Best place to DYNO & TUNE?
OSH13T
 Share
tan18d, feel free to do so via PM. As far as I understand, you cannot bad mouth companies here as it is somewhat of a public pladce and SAU could be sued for defamation...
that's what I thought anyway but I'm not an admin......
  • Replies 53
What Ronin said is right - We do this to protect SAU from any possible recourse.
We wouldn't want SAU taken down for something that can be avoided.
People have seen your story and are welcome to use PM or private e-mail if they really want to know more.
Thanks for understanding.
  • 3 weeks later...
Thought I would let you know that I had my Apexi tuned at Ric Shaws yesterday.
I had the last tune(s) at a different shop (had to take it back) after my engine rebuild and I could feel that it wasn't right, Ric's dyno read that it was making 152rwkw. After Ric had finished it made 185rwkw. This is a result I can feel, in perspective - a 20% power increase, plus the car is generally better behaved.
He did keep the car overnight, which pissed me off 'cos I had to catch a train home (2.75hrs vs 1.25hrs in the car) but he needed the car to get it right.
Total cost $330 = less than $10 per kilowatt.
Bonkers,
A great result - I used to take my Series 4 rotor to Rics, a few years back - they were always good, affordable and professional.
Do you know if Ric can tune EMS ?
Cheers,
ohshi3t, the problem with mines ECU is that the eprom is glued too securely to the circuit board. Open it up and take a look you see a secondarycircuitboArd on top of the factory one. And if you unscrew it, you'll notice the there is a shitload of glue on the ROM,making impossible to take out and therefore no one cept mines can tune the mines ecu. If you decide not to go aftermarket, i think you can desoilder the secondary circuit board and install tuned rom yourself.
Unique is getting a dyno in the coming weeks which will mean they will be able to dyno tune your car.
Very handy - especially now they will be a one stop shop
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
