you can get a engineer to approve disabling emissions equipment??? :) if you get defected for that and fight it, the engineer might end up in a whole lot of bother...
the reason an atmo BOV is illegal is the air can contain pollutants (hydrocarbons and the like) from the crankcase (via the PCV) that are not legally allowed to be vented to atmosphere - they have to be burnt and passed through the cat. it has nothing to do with being filtered on the way out. filtering does not remove any emissions or make it legal.
my car has atmo bov's too, but good luck to any police trying to see them!
That is correct, so the way to do it properly is to have a proper plumbed back oil catch can system. So all that is venting is normal air that went in in the first place.
Point is, if you have a proper engineers cert with you the cops will probably leave you alone as its too much hassle for them. If they do book you, with a REALLY good lawyer you could twist it back around on them and try and get themselfs charged with wasting police time and tax payers money, as you proved to them before receiving the ticket it was engineered. If you had the money it would be worth a laugh anyway.
  • Replies 40
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
