Hi again,
the turbos are hks gtr-s but i was told they were rated at 450hp, and other sites I have researched agree with that.
When in doubt, refer directly to the HKS goodsmaster catalouge - They are not rated at 450ps so a workshop should not be making those power claims.
  • Replies 57
I would definitely reconsider your plans and any associated costs/quotes/budgets as what you require won't be cheap. I would also recommend a more suitable workshop for such extensive mods, unless you have plenty of time to wait and money to burn.
Either way a 450rwkw GTR wont be cheap to run and maintain-mine only had 370rwkw and had a large appetite for gearbox's. I fixed the problem with a full OS Gikon set. In hindsite should have spent all that money on something else >_<
Im at a time in my life where I can burn a little cash off having fun but if you can tell me more about the box you bought - where from, how much, it would be appreciated
I may have one for sale...pm me if interested
again....what oil pump and sump are you planning to run with this combo??
Edited by DiRTgarage
definately be used on the street. will see the track regularly too. the car is almost ready. will be going for its dyno run on wednesday. had it on dyno last friday and it hit 380 kw no prob. graph was climbing steep but noticed small amount of oil coming from one of the turbos so stopped the run. Both turbos now back @ shop getting new seals. warranty job. turbos back on car tomorrow. will post graph hopefully wednesday night.
Edited by fritter
  • 3 weeks later...
Just got the GTR back on Friday morning and after a few days on the gold coast have now driven it up from brisbane to townsville. ITS AWESOME. HILLS MOTORSPORTS have done an awesome and thorough job. Im very impressed. 447 kw at the wheels. 1012nM of torque. I ended up having to get a new gearbox and opted for the P.A.R. straight cut box. Feels smooth to change but does have the usual whine in 1st 2nd and 3rd. full kit cost me $5300. I will running it this week end so i will keep you all informed of my 1/4 mile times. Must repaet again what a great job mark from hills did. I know there are some people in here who think otherwise, but he has impressed me.
Edited by fritter
Ended up sticking with the gt-rs turbos. they come on hard at around 4300rpm and go hard to my 8600 rev limit. I will post pics of my times on monday. Im aiming for mid 10's until i get used to launching it and hopefully my times will drop a bit more soon. I have done a couple of practice runs on an old dead end road out the back of townsville and using my rev/speed monitor i got down to 10.72
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
