Well after reading that i am not sure what to do ?
My head is milled with minimal machine marks but the block is quite visible , surely removing all the coating on a MLS gasket is not necassary when the engine has not even been fired.?
This seems like another waste of money , there must be advantages in using a copper HG as it is more maleable.
So - if my block is assembled and in the bay now - what head gasket should one use? Can i prep the block in there , i don't think so or spray or coat the surfaces for block and not head. I will be running bigish HP - not sure what direction to go in as some other workshops say the MLS will seal when exposed to temp ?
If reusing - tourqing up the studs a few extra puonds should do the trick.- your opinions :P
I DON'T THINK TORQUING UP THE NUTS A BIT EXTRA IS SUCH A GOOD IDEA , HOW ABOUT USING A COPPER HEAD GASKET SPRAY ON THE TOMEI GASKET , I KNOW YOU HAVEN'T FIRED THE ENGINE YET AS LONG AS YOUR HEAD IS FIXED FROM THE WATER SEEPAGE I DON'T THINK YOU'LL HAVE A PROBLEM
i have a pretty good idea on why mine is weaping oil - the place that decked my head is different to the place that decked my block, and im pretty sure the place that decked the head would not have gone to the "ra" that was required - as they normally do machining for normal motors, not really high performance alloy motors such as the SR20, RB26 etc...
Im going to hit the place where mine is leaking oil with a bit of carby cleaner/degreaser and a air gun and see if i can use some silicon around the place where its weaping and see if that will stop the leak - sure its a bit dodgy and crude, but its on the drain back side of the motor so im not to concerned...
What tha??
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
