hye.. im new here.. ive been reading this forum for quite a while now..
i own a er34 skyline, ive worked my ass out to buy this car..
im currently a student staying in japan for now..
the problem is.. when i accelerate in 2nd gear.. (ive set my boost up to 1.1)
the boost reached 1.1 but then the boost started to drop slowly before i can reach the redline..
ive installed powerfc, profecb..
any suggestion ? pls any help guys... :(
https://www.sau.com.au/forums/topic/125559-problem-with-my-boost/
any suggestion ? pls any help guys... :thumbsup:
You in Japan? take it to the Nissan dealer!! :wacko:
are you running the stock bov? if you are it could be leaking under the higher pressure.
is it stock turbo? if it is then it probably can't cope with that amount of boost, so at higher rpm it is forcing the extra air to go out the wastegate. my mate has that prblem on his sr20.
also what dump pipe are you running? that could possibly be the problem too.
im using the stock bov..
ive used HKS SQV but.. when i pressed my clutch for an amount of time. the engine will suddenly die.. so ive changed back to the stock bov..
it is a stock turbo.. so i must change my turbo to solve this?
also what is a dump pipe? hehe..
    • Just something I found searching for more info on Emotion R, apparently the ECR33 Skyline GTS25t was either originally black, or there were two of them, the black one being the original demo car, then building a white one which was part of the 1997-onwards (to at least 2008!) Cockpit Tatebayashi Tokyo Auto Salon booth demo cars. It appears that Emotion R closed down in 2008 and was declared bankrupt in 2010: http://bank-db.com/hasan/208365. Scan of a magazine with the black R33 from 1996: Wayback machine archived page from May, 2000: https://web.archive.org/web/20000529061027/http://www.emotion-r.co.jp/skyline.html Option magazine with a few photos from the Cockpit Tatebayashi booth at the Auto Salon from various years: 2002: http://www.jdm-option.com/photo/index.php?action=item&category_id=154&image_id=3507 2003: http://www.jdm-option.com/photo/index.php?action=item&category_id=137&image_id=3033 2005: http://www.jdm-option.com/photo/index.php?action=item&category_id=116&image_id=1831 In 2008 Cusco website mentions that the Cockpit Tatebayashi ECR33 was displayed at that year's Tokyo Auto Salon: https://www.cusco.co.jp/event/2008/12/post_735.html As of 2021 it appears that the ECR33 demo car ended up being exported to Florida, USA: https://rmcmiami.com/inventory/1996-nissan-skyline-r33-cockpit-tatebayashi-demo-car-big-te06-turbo-endless-brakes-lsd-450hp/ And finally here's Google streetview of the Emorion R garage in 2023 which is amazingly not only still there, but the showroom is still full of various parts in stock and funishings, etc.: https://maps.app.goo.gl/ttyEAZdZLyzermyT9 Apologies for nerding out a bit. I used to love doing this 20 years ago on SAU and got a bit nostalgic for a moment... 😅
    • Try fabricating something like this and install it under the pedals? Not sure if it's legal or not....
    • Even though I have some pretty good (brand) ratchet ringies, I avoid using them to break open tight bolts. A broken ratchet is very annoying.
    • Also, there's always room for 4 or 5 3/8" drive wobble extensions of various lengths so you can operate the ratchet from a better location.
