  siddr20 said:
so do you still want me to test your car out or not???
pm sent
  RBFIRE said:
lol,
No,
5000rpm in 1st,
what is traction?
lol
Why not find out if u have an after market suspension or not?
look at it, most of the time, u can tell them stock apart from aftermarket.
or snap a pic and post it on!
Do you mean to say that I shouldn't expect traction in 1st at high rpm's? I went for a ride in my mate's 200rwkw s13 and it had no problem to the redline. And I think I mentioned mine has no trouble if I have a passenger for a bit more weight. MajorSick also said 370kw and no problem with traction. So what do you mean?
I'm pretty sure previous owner said it was aftermarket. He said something about the importer giving him a choice between a couple of setups... not sure exactly what was changed.
So if you think it would help I will try to get a camera underneath it. When it stops raining of course... lost my garage spot :wave:
  bombastic said:
Can your sava's hold traction in first, and if so do you also have an RB25DET? If so then that would indicate my suspension is the cause of loss of traction.
Yeap it's a RB25DET, but it's an auto though, so take off is relatively slower and not as quick as a manual, so I don't have any problems with traction with the Sava's.
I am not saying the sole cause is the tyres, it does sound more like your suspension needs an overhaul but the tyres do make a difference. Just fitted Toyo's T1R's and I have to say they make a difference in terms of ride comfort and soaking up pumps over the Sava's :(
Edited by godspd
ok went in andrews car today..
Wasnt as bumpy as i thought it would be.. A bit more harder than my suspension, but its really not that bad.
I just think hes got some shitty tyres. Hard compound tyres and also the pressure is a little high i reckon.
I got like 1mm of thread left in my rear tyres, and i didnt loose traction in 1st when planted right to 7000rpm.. We got big sideways in one of the corners, but thats expected around a corner.
Anyways andrew i think its just your tyres.
But maybe do an inspection on your suspension if you want.
Edited by siddr20
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
