Hmmm i wasn't sure on the reasons behind, thanks for that. I just know that shipments that have been order to australia, (apparently comign from Japan) are beign delaid, i think your probaly right, the fact there new on the market is obvioulsy another reason why theres a delay.
  • Replies 57
I didn't know it was made in China.
Fair enough my point still stands though - if you NEED a $750-$2000 kit get one. If you don't car or just need something for 200rwkw then get the forum sponsor nonames.
I'd still be going the Calsonic :D
I have one..Calsonic FTW!
I want to see if the piping and fitting for the GReddy kits is as bad as the ones for the Hybrid/JJ/Generic kits...
I'd hate to see a step down for a reputable brand such as GReddy/Trust to have an instruction such as "Step5: Hack off this part of your radiator fan"
It's generally accepted the actual FMICs are the same quality that can handle the same amount of power but in my opinion the quality of the kits is reflected in the piping/fitting and not the FMIC itself.
Wink the piping for the Mspec folows the exact same route as teh V-SPL kit. The actully piping is probably better then it's more expensive trust counter part, as it uses all silcon hoses and not rubber, and the actully piping is pollished steel for the ppl who want that shiny bling look.
The Mspec kit has "GReddy SPL-V" piping (except has Silicon joiners- SPL-V has rubber hose)!
The Cores are made in Taiwan but made to Japanese Standards!
There wont be anything wrong with them, personally id rather buy GReddy as all the pipes and everything will fit up nicelly! Plus im not planning for 250+rwkw's
Quote from nissan silvia:
"We have spoken to Greddy/Trust Japan and the Intercooler Core is made in Taiwan, however the Quality inspection and control has been done by Greddy Japan. Piping is the same as V-Spec and is made in Japan."
Link if u r interested!
Edited by hawker05
Shit if this offer was available when I got my FMIC I'd have paid $100 so I wouldn't have to either
A) Cut up my rad fan
B) Modify the piping brackets to fit the kit on without doing A)
Also my JJ kit has REALLY thin piping. When you knock it with your knuckles it feels like you could bend the piping with your fingers.
hey all, i dont know too much about fmic bout i got quoted $700 fitted from the place i bought my car from, i know its only some sort of hybrid but the piping and connections are silicon (blue) and seem to look good. I know there probably as good as the other ones going around but isnt it better to have a good shit one then a shit good one, if that makes sense, lol
zGee thats cheap for the gtek. Do you have to cut the bar etc?
Is the Gtek one a bit too big?
Is it 2.5" piping?
Cheers
You have to trim the front bar (as with almost all intercooler kits).
The piping is all 2.5" polished mandrel bent aluminium.
cheers,
Greg
  • 1 month later...
I know this is a bit of an old thread, but I thought I'd revive it as I've been looking at this situation myself & I have a few questions it would be appreciated if some people could answer.
How much better is a Tube & Fin intercooler over a Bar & plate & how critical is the end tank design? Not sure which would be the go in absolute performance terms as far as a cheap tube & fin vs an expensive good performing bar & plate type one.
I also eventually want to go a front facing plenum as the long term plan is for 300+ rwKW so the Piping won't be permanant. Would I have to cut the hole under the battery plate further forward if I was to change to a front facing plenum? I don't want my car to be a butchers special.
I have looked at the V-spec Greddy/Trust tube & fin cooler too, but I can't see that the price of it over the Hybrid is justified. Sure it fits right & has better end tanks, but for double the price? It'd wanna be made in Japan for that money!
My other alternative is to just wait unit I got the money for the plenum too & go full custom.
Any input appreciated. Cheers
Edited by JazzaR33
For the price of $349 we sell full Intercooler kits for the GTS-T's.
The intercoolers will support 300rwkw's without a problem.
If you're talking in terms of Hybrid *tube and fin* VS the bar and plate there is NO noticable difference. The Hybrid *tube and fin* is NOTHING like a japenese tube and fin. It's more like a bar and fin... ?
BUT If you're talking in terms of bar and plate VS Japense tube and fin, then you might have a slight difference but I have still not been able to tell the difference between coolers with close to 300rwkw's (r32 with RB25 and TD06 high mount setup).
If you use one of our kits (or equivelant) then there really isn't a need to cut another hole later on as the piping can still run through that side of the car and is pretty much in the right location for a front facing plenum. You would just need to lose the top cross over pipe and get 1 pipe made up (probably cost $100 or so to get custom made in stainless).
Value for money, there is no point of going Hybrid, but if you like brand names then the Jap coolers are great :(
That's my opinion and I use these on my own cars...
Greg
Edited by EXAUNV
One other thing I did forget to mention. I don't want to be chopping the crap out of my front structural beam either. After witnessing a rather horrific crash involving another 33 I want to be sure I have every mm of that sucker in front of me.
Thanks for the info EXAUNV
I don't think there's any aftermarket front mount intercooler kits that don't require you to cut into the bar re-enforcement.
When the intercooler is there and supporting the reo aswell, I think it is okay (only a small amount has to be cut out) (just don't remove it all together like some people do!!)
Greg
I would also like to see some definitive answers to your questions too. The CRD tube and fin Hybrid copy FMIC for $379 looks alright to me, but if it is quite limited then I don't want to have to upgrade to a V-spec or similar at a later date.
Glad you dragged this one up.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
