Selling my CB as I don't use it anymore.
Asking $80 firm with almost new microphone, and short antenna
Erik
Does it come with the magnetic base?
where are you located?
It does come with magnetic base for the antenna
I'm in Perth
Do you still have the mounting bracket?
does it say anywhere on there that it handles 24volts?
will you include postage to vic in the price?
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
