good info Mad082,
My main point of fuel consumption is to not have the turbo even boosting and hoping that the auto is changing at 2,500rpm or there abouts when driving normal, taking it easy.
My theory was that, If turbo is boosting the engine is pumping through more and more fuel as thats the point of the turbo in the first place, force air and fuel into engine. So if it is not operating I have 2.5ltr n/a economy.
If I give it I have rb25det power with larger turbo + bad fuel economy?
Am I making sense or correct in what I say?
Cheers
Thanx for all the replys, very helpful info as when I do something I want to do it right the first time (on a budget :thumbsup:)
"quote"the more air you put into the motor the more fuel that has to go it to make it run at the right air/fuel ratio. for example if the bigger turbo at 4000rpm flows the same amount of air the standard one does at 7000rpm, then at 4000rpm it is going to pump in the same amount of fuel as 7000rpm on the stock turbo. if you are worried about fuel economy, then don't change the turbo."quote"
Edited by MZTRBO
FYI,
I have been cruising with another fellow member of sau Legend01.
Legend01's car was putting out 280rwkw's with a laggy turbo (rb20).
On this cruise we had both filled up full at the same time. The entire cruise was that simply crusing, as legend01's car was just in a run in/check everything okay phase.
At the end of the cruise (Id say easily 120-150klms) my petrol tank was just above half way. Whereas legend01's petrol tank was just off the full tank mark? I know that it has 500cc less capacity, though people do say stock for stock they have similar fuel consumption.
This is were the laggy turbo taking it easy theory = good fuel economy comes into play.
  • 9 months later...
hi,
This is 8months old now, but I have results from my first post..
I ended up gettin the turbo on, it was hitting R&R badly..running rich as...
before turbo I got dump pipe also..
Anyways ended up making good power 234.9rwkw@11/12psi..
Fuel economy is great..went for a drive after safc tune at hitmans...180klms so far to not even 1/4 tank..im sure i will get 450-480klms out of full tank..
theres a thread in forced induction with results n graph FYI
Cheers
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
