sorry for the newb question fellas, but i was wondering; by rebuilding the bottom end, does it affect the compression of the cylinders in any way? ie. would a low compression turbo engine (which is bad) still be 'bad' after a rebuild? Also, what are the safe compression levels on an rb20det?
cheers, miguel
https://www.sau.com.au/forums/topic/125623-engine-rebuild-question/
Are you referring to the engines CR and it being bad cause it was built bad originally? or do you mean the engine is shagged from old age and abuse and the compression has dropped and needs a rebuild...if the latter then yes an oversized bore with new pistons and rings to suit will ensure compression is good again and tolerances are tight.
Id imagine compression would be around the 160-170 mark..similar to an rb25.
from memory, anything between 127psi and 170psi is good compression, and variance of no more than 15psi between cylinders (these are from rb20det manual if i remember them correctly)
low-compression related problems can arise from
-piston rings (or cracked piston / stuffed bores)
-head gasket
-valves / head
bottom-end rebuild will include new piston rings and will fix any bottom-end related compression problems.
Usually to tell if your rings / pistons aren't holding compression you can add 10ml or so of oil to the cylinder when doing the compression test, if the comp increases then your rings are gone.
(not to be confused with 'compression ratio')
when rebuilding an engine you can lower the compression ratio by taking material out of the head, however this is completely different from what i've mentioned above, and low compression ratio's aren't necessarily bad, particularly for turbo's which are more prone to detonation. An aftermarket thicker head gasket can also lower the comp ratio.
it would be impossible to detect if the comp ratio has been altered without taking the motor apart.
hope this answers your question
Edited by MerlinTheHapyPig
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
