Got a Blitz exhaust and its a tad loud so ive put it for sale. I dont really want to sell it becuase its looks really nice on the car.
Then i came across the Apexi ECV.
It can also connect a electrnic controller like the pen type turbo timer apexi have.
-Has anyone got this?
-Is it effective?
-Does it decrease power much?
Any info at all much appreciated.
Thanks,
Phil.
Edited by PAV34
https://www.sau.com.au/forums/topic/125632-apexi-ecv-electronic-control-valve/
It decreases power ALOT. When the valve is fully closed, if I plant my foot, you can actually watch the revs climb about half the speed as normal and the engine chokes.
It's very expensive.
It doens't help you with exhaust noise test because they'll just open the valve.
It does make it a bit quieter, but not a lot.
your best bet would be to install a middle muff
ive got a split dump/front, hi flow cat, resonator then the muffler.
should i replace the resonator?
what else could i do to make it quiter without losing performance?
Edited by PAV34
But keep in mind, no matter what anyone says, acording to the lawsof physics, less noise generally means less power.
that is only true to an extent. a 3" exhaust on a charade will give it less power than a 2" as it doesn't have a big enough engine to put enough air to fill a 3", but it will be noiser than a 2". it depends on the muffler. if it is just a straight through, perferated pipe muffler it won't affect performance. the cat slows the air down more than a most mufflers (unless they are the winding type that look like a 's' inside).
if you want to quieten down your exhaust put a straight through 'hotdog' resonator in, 1 with the raised holes. this will take out a fair bit of noise, and you won't notice any performance loss. those noise valves even make a difference when they are fully open. they slow the air down so there is a slight loss of performance. as the air travels through the exhaust it swirls slightly. the valve interupts that swirling (even when fully open).
Edited by mad082
I had a new custom made 3.5" polished stainless exhaust fitted to my car exactly a week ago and its very quiet compared to what I had on previously.
The previous exhaust was a Do-Luck 3.5" cat-back that had a middle resonator and a maaaassive rear canon with 4" tip. The exhaust was soooo loud I couldn't even let my car idle in my garage (detached from house) or driveway because it would make the front/side windows of our house vibrate that's how much it droned.
I had Eddie at Penrith City Exhausts have his way with it and the results are simply incredible. I always thought big hp means big noise but it's not the case if you use the correct mufflers (note I said mufflers and not canons). The canons are pathetic and removing the noise so I had a big oval magnaflow muffler put in the rear and a fairly big magnaflow center muffler added and it's all nice and high off the ground (i'd say 3-4cm higher than the previous exhaust).
It's nice to drive a car that doesn't drone at 110km/h in the motorway and also now I can let it run on the turbo timer when I get home without waking up my neighbours.
yeah cannons are pretty crappy at reducing sound. an oval muffler will always take more sound out. the best are the jasma split mufflers. the pipe comes in as 1 3" then splits into 2 2.5" then joines back into 1 3" then to a 4" tip. thats all just in the muffler. if you look up it you can see split as it is just like an big oval with a partition down the centre.
Both my magnaflow mufflers enter 1 side and go diagonally across the muffler and exit the opposite side
that gives a little bit more back pressure (only the tiniest amount) and increases surface area, which increases how well they work. having them at an angle makes the sound particles bounce of 1 side into the other and just keep bouncing the whole way along. think throwing a bouncy ball through a pipe. if it is straight then the ball will just pass straight through. if you put it on an angle then do it it will bounce from side to side. the air still flows through about the same, but the sound is less.
Edited by mad082
I hav an apexi ecv with elec controller.. took my exhaust (100mm) on a gtr from 105db at 5000 dowm to 92db to clear a defect that i recieved... the valve will only work with it 100% shut... i really didnt like putting that much of restriction on the engine... the motor just didnt feel right driving with it fully closed. then comes the problem with it closing up at high rpm... everything was fine until we started running over 15psi and now we cant keep it from closing up and still hav the use of the electronic controller.... we added extra spring tension to it but affects the controller it attemps to operate the flap and cant so it goes into error a mode... we cant find a happy medium so at the moment its wired fully open and will stay that way...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
