thinking about putting a set of adjustable cam gears on my r34 rb25det neo, just wondering if anyone has some tips they can share or run into any problems installing them? what to do about the variable cam timing on itake and exhaust? if anyone has done this with a neo engine pics would be great if you could post them up.
thanks.
https://www.sau.com.au/forums/topic/125697-adjustable-cam-gear-on-rb25det-neo/
R33 & R34's have variable intake timing only and yes you can get decent gains by adding an adjustable cam gear on the exhaust side.
Best time to do it is when you need to change cambelt and associated tensioners and do it all at once.
A decent mod for $200.
No point doing it for looks though as it will be behind the cover.
i was actually looking at putting the adjustable cam gears and gates timing belt on and modifing the greddy rb26 clear timing case to suit the rb25. but if the intake cam gear still has to have that ugly alloy cylinder on the end of it, it may be pointless doing the mods as i was only really interested in doing it for the looks.
Yes it will look good mate. I have heard mixed results in regards to performance by ajusting the exhaust cam gear but could not get a straight answer on this. Has anyone here completed this mod with noticable results?
but what about the ugly cylinder on the end of the intake side cam gear????
yes, but then i replied before. when u do the timing belt it is a no brainer on an R33. you should pick up around 5-15kw most of the way thru the rev range. roughly 4 degrees give or take depending on what you get on the dyno.
R34 neo engines seems to be no gain.
Edited by wolverine
Walkoau, Pm'd SK from Stagea page with fitting adj. cam gear to NEO. VVT on inlet, can fit a.c.g. to ex. I have an R33 gear to put on my Stagea. SK has run his at -4deg so far. Great post in Stagea page showing how to fit (in DIY).
  • Like 1
thanks for the info, so no need to fit a a.c.g to inlet side cam because of vvt, only worth doing on the exhaust.
I hope your correct I am up for my 100k service shortly. I will have one fitted and dyno tuned with my SAFC2 and post a back to back comparison. The charts I saw were putting out low power to start with then I saw an extra 15kw or so like you said. Im making 195rwkw already so hopefully this mod will push me over 200rwkw.
cheers
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
