Hi there ,
I took off the cover and blah :D
How can you have a harness looking like a dogs breakfast.
Anyway ,does anyone know what sort of products are available to prevent heat from getting
to the wires and do i take the black insulation off or wrap something around it.
Nissan obviously did not think we would see that crap.
https://www.sau.com.au/forums/topic/125743-coil-pack-harness/
Yeah put the plastic cover back on. Thats why its made out plastic. Ever wondered why nissan didnt make it a metal cover....?
Most people drive without it on, apparently this is to help the coils ,
Anyway still hasn't help me. But thanks for the comment... :unsure:
cut holes in the cover to release the heat and mesh the holes over.....did mine and looks sweet! and gets rid of over heating on my spitfire coils!
Well then know one knows, ill have to get an auto elec. to work on it then.
Thanks for the replies though
Ya.. Mines aluminium...
so is mine.
u can get vented ones for about $120 if ur really keen. Or just leave it off. But with the S1s they have an igniter that sits on the cover so u will have to mount this somewhere...thats what I am doing sooner...or later
I took mine off yesterday after installing the splitfires - i'm not gonna let what happened to my stockies happen to them.
I took to the cover with a hacksaw, cut it off just infront of the ignitor so it sits in there fine and the 6th coil still gets pleanty of turbulent air for cooling.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
