hey peoples
Does anyone know where i can get some chrome dipping done
in the eastern suburbs of vic.
Was hoping to have a couple things done.
Mainly my greddy plenum.
Has anyone had stuff done before?
Was curious of the costs and times etc involved?
cheers everyone.
Guesty
https://www.sau.com.au/forums/topic/125745-chrome-dipping/
hey peoples
cheers everyone.
Guesty
Greddy plenum is alloy, you will need to get it polished not chrome dipped.
https://www.sau.com.au/forums/topic/125745-chrome-dipping/#findComment-2321863
i know a guy in bayswater who does alloy polishing
comes up very micky mouse!!
Have ya got his details?
Im only in ferntree gully so it's like the next suburb over.
With polishing do i have to maintain it every so often or anything?
any idea on costs?
https://www.sau.com.au/forums/topic/125745-chrome-dipping/#findComment-2324303
Often wondered if after getting something pro polished wether it would be an advantage to spray it with totaly clear plastic circuit PCBoard spray that is fairly hardy stuff and pretty cheap. Should stop the polish from dulling off over time I would think.
Anyone tried this?
https://www.sau.com.au/forums/topic/125745-chrome-dipping/#findComment-2325666
Anyone tried this?
i would think heat off the engine would be the main pitfall... sayibg that it is a brilliant idea :sorcerer:
br interested to see if it acctually worked
https://www.sau.com.au/forums/topic/125745-chrome-dipping/#findComment-2326026
Anyone tried this?
nope it doesnt work.....it will turn a milky white colour....then what happens is the clear chips off and corrosion gets underneath it ans it look shite
https://www.sau.com.au/forums/topic/125745-chrome-dipping/#findComment-2326954
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
