Well here is my problem...
Plug in the pfc. The hand controller doesnt turn on. Put keys in and turn it to ACC. The hand controller turns on. Turn off the boost controller unit.
Turn the keys to "ON". At this stage the engine light and the exhaust temp sensor flashes repeatedly and I can hear a tapping noise comming from the fuel pump. Fuel pump seems to prime. I wait awhile crank the engine to try and start it and it wont budge!
Plug back the stock ECU and everything works, car starts, just doesnt like the PFC.
All alarms are turned off. (That I know of)
At first I thought it was a faulty PFC, but I tried another PFC and it did the same thing.
S1 RB25DET 5 Speed Manual.
I have no idea what is wrong. Suspecting its a wiring problem? The stock ECU is an old one with some sort of diagnostic knob at the back of it. :
Edit: In case people dont read this was fixed, cause is explined here: http://www.skylinesaustralia.com/forums/in...t&p=2327813
https://www.sau.com.au/forums/topic/125792-how-to-install-a-powerfc/
Ill take the stock ECU out tommorrow and get some pictures.
Hmm had a re-read of paulr33's pfc faq and this might be my problem?
"Some cars only (for some strange reason) have half gauge wiring running from the battery to the ECU. This works fine for the factory computer but the PowerFC needs the full 12volts. You can simply run new 12volt wire from the battery to the ECU and this should correct this. This problem has been experienced by at least two members previously (both in R33 GTST)"?
I am unsure how the 12v feed will affect the PFC, other than "it doesnt work", I know the hand controller runs of a 5v feed. Try this.
FC in and hand controller in
turn to ACC
check out SENSOR SW CHECK under ETC
post up what sensors are in black (backlight) highlited
Hmm ok I have some pics of my "stock" ECU. See below.
This is what I just tried before..
I tried plugging in the PFC again. This time I took note of what happened.
Plugged in the wiring loom.
Plug in hand controller
Disable alarm
Turn the key to ACC. Nothing! Hand controller doesnt turn on! wtf?
Turn the key to ON, Hand controller comes up APEXI Screen then it just freezes at the "RB25DET" screen.
All this is happening whilst the engine light and exhaust temp sensors are flashing and the ticking sound is heard from the fuel tank.
Once again unplug everything and put stock ECU back and everything works fine.
Weird thing at back of ECU:
ECU Mounted:
Hmm after talking to people. Seems like the pic above is a stock ecu and nothing special about it.
This leads me to the wiring. The plug loom u see there is for the AVCR.
Or possibly the pfc isnt recieving enough volts at ACC to start up?
As the stock ECU only needs 8v to start, while the pfc needs the full 12v?
Hmmmmm
The PFC h/c and fuel pump prime should only show/be heard when in the on position, then a further turn to start will have the car start, letting go of the key returns it to the on position where the car continues to run.
Check the sensor sw screen and post up ALL of the values, preferably take a photo of the screen and post it.
joel, from what Victor has told me. it stays on the RB25DET version screen and doesn't continue through that point to the menu's. he was able to get in there ONCE while at hitmans to turn off the boost control.
he told me also that the AVCR doesn't have any values for INJ/TPS etc coming to it.
also what i found was strange, he said it doesn't Crank over when turning the key to start.
ahh no problems...
When my pfc was in for repairs it would hang on the intro screen when it wasn't receiving certian inputs. i.e simply running power through it. Once installed it was fine.
Its also been known for the plug to be slightly off and not done up straight causing it too to hang on the intro screen.
But yes if the avcr isn't receiving values either then something is definitely up. :unsure:
I would check removing the ecu hasn't broken/distrubed the work done on the loom when the avcr was isntalled.
should have elaborated a little..
the AVCR works fine when using the std ECU, but not at all when using the power FC.
edit - did yours crank over and just not start when your PFC fried ?
Edited by Craved
Havent checked fuses.. But with the std ECU works fine.
It may be the PFC simply not recieving enough volts. or wiring missmatch, though I cant see why.
Ill try jump starting it via jumper leads tommorow. Unless its bad to do this. :
It all too confusing right now..
jump starting it is, but if wont go past the rb25det version display then theres no point. the FC is locking up for some reason.
turn the car off.
hold up on the hand controller
turn it on.
what comes up?
d00dz I wouldnt be experimenting to much especialy with straight power ! I know nothing about this but hard wire jumping the car or Ecu cant be good ... get it tested or give it A fresh 12 volts but lighty fused...
Get it tested Professionaly so you know
You dont want to blow any Warrenties because your frustrated !
jump starting a car with a PFC is no different to stock ecu.
ive done it before twice and it works just as normal (as its supposed to).
it sounds like you have the wierd wiring (not 12v guage) at a guess
Hi Guys
had exactly the same prob the little blue relay next to the battery in the boot ticks like mad. iafter ripping half the dash apart and checking all the voltages from the pinouts it was just the fuse the fuse box has two rows top to bottom its the left hand row sixthfuse up runs fine on old ecu -nothing but start screen on PFC
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
