waits to see if steve saves the day :wub:
Jump starting the car ey?
As Chris says which one pfc or car or both the same? :
Do I do this by placing jumper leads to the terminals and starting another car then start my car with the PFC in?
you wouldnt jump start the PFC ... i was making a joke
checkout what Coastlife said about the fuses
WELL!!!!!!!!
I checked the fuses under the drivers's dash.!
And I noticed hmm wtf.. one 10AMP red fuse is broken.
Dunno how it was broken but it was! Replaced the fuse and pfc works fine and car starts up with it!
So Paul I reckon in your tut put in to check all fuses if pfc doesnt work. :thumbsup:
Now the only thing that sounds or looks weird to me is:
When I turn the key into "ACC" the hand controller doesnt turn on. However when I put it to "ON" it does. Whats wrong with that?
Its not meant to turn on when you flick to acc.. acc is onyl for sitting there with radio on etc.
The on position is when it primes the fuel pump and gets ready to start
Sweet! Im ready to go then.. YES OMG ffs
CHECK FUSES FFS
Thanks everyone for helping! Top marks goes to SAU and its members again! :thumbsup::):yes::( :(
Esp Steve and Chris :):worship: :worship: :worship:
Hi Guys
had exactly the same prob the little blue relay next to the battery in the boot ticks like mad. iafter ripping half the dash apart and checking all the voltages from the pinouts it was just the fuse the fuse box has two rows top to bottom its the left hand row sixthfuse up runs fine on old ecu -nothing but start screen on PFC
Paul FYI:
Yes Steve is correct. According to the diagram: http://members.dodo.com.au/paul/diagrams/r33-fusebox.html
The fuse that was broken was "Left Column, top to bottom:" -> "10A – Engine Control"
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
