hi guys... well i noticed this morning as i reversed outta my drive a wierd 'click' coming from the front end somwhere. i have to reverse at an angle as i have a steep drive so the car was on the angle coming out of the drive. i drove up the street slowly and turned the wheel a few times and its clicking when the wheel is at almost full lock. also tried a 'heavy' brake and the same noise occurs.. is it most likely a worn suspension bush or some prob with the steering rack? i think i need my steering rack boots replaced as one of them has split..
any help would be great!
james
https://www.sau.com.au/forums/topic/125800-front-end-clunk/
Need a bit more info.What changes have been made to suspension.EG: coils,springs bushes.
Get it checked for caster bushes and ball joints.I have the same thing and all have been replaced, except ball joint.You have to get your mechanic to look very close when he jacks it up by the chassis so the wheels are off the ground.If you hit the top of the wheel you can actually see the top of the ball joint move a whisker.
https://www.sau.com.au/forums/topic/125800-front-end-clunk/#findComment-2324119
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
