have a look a this link I thinck it mentions something about, The unique ported shroud was designed to minimize compressor surging at the mid-range rpms.
http://www.dragsport.com/issue/2006/0706_tech.shtml
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2322509
RBSandy they are the vent paths for the ported shroud within the inlet boss . 2rismo I'm not sure what you mean by they are covered by the filter or inlet ducting ? So long as the vent paths can vent air from the radial slot in between the main and splitter compressor blades to the atmosphere side of the boss they will work . I have a feeling that HKS do this partly for bling factor (marketing) but I also get the feeling that doing it like this or by having the trumpet mouth insert like say their GT3037's have reduces the shrieking screaming noise that the more common port shroud like say a GT30R (GT3076R) tends to have .
Thanks for the link as well , always wanted to see inside the HKS TO4Z comp cover .
Cheers A .
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2322654
the holes on the comp cover are a workaround for compressor surging
it allows air to enter onto the compressor wheel on the outer edge to balance out the some of intake sucking, which is commonly associated with surging. think of it as an anti surging device.
the bulk of the air enters the snout, thanks to the vacuum effect of the compressor wheel sucking in air, but a very small amount enters through the holes also to side step around surge
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2322783
wonder if it would surge with the holes blocked off. logic would say yes.
i guess that was the only comrimise they could come up with to avoid surging. must be a really wacko compressor/housing combo (sounds logical??)
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2324260
It's not very hard to picture. How many of you run no filter on your turbo? Do you all have a pipe from the compressor inlet to an air filter? Would the holes be obscured/covered on a T04Z like this?
Tell me what they're for in that situation?!?!?
Adrian
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2325025
2rismo I can't follow you logic , if you mean "covered" as in out of sight then 99.99% of port shrouded compressor covers the world over are covered . This does not prevent them working as they were designed to . Many Diesel turbos have port shrouding and very rarely are they run without ducting to an air filter . If the manufacturer wanted it not to work the gas ports would exit the cover through the outside of the boss ie the parallel section behind the barb .
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2327007
asmuch as i would like to believe that its just bling factor, HKS have obviously done some R&D into this turbo with a particular housing combo and realised it surges, whether its engine and boost specific or whatever. 2rismo, doesnt matter if thier plumbed back into the induction pipe. thier there to releave flow when its surging.
and if its all bling why wouldnt they do it with all thier other turbos?
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2327095
Adrian
I dont get what you mean either, the pipe sits OVER the housing, not inside it.
So the holes, no matter if a pipe fed the bellmouth or not, would still flow air as designed
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2327252
Adrian
Im not getting you either :wave:
Silicon joiner gets hose clamped to the outside of housing, holes on inside. Why would the holes be obscured?????
https://www.sau.com.au/forums/topic/125801-turbo-question/#findComment-2327260
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
