I reckon that turbo can support a lot more airflow (power potential) than an RB25 could reliably withstand so a bit pointless unless you beefed up the internals . To get the boost threshold down to an acceptable point for a road car would mean using a small AR ratio exhaust housing so the 750 odd Hp compressor is wasted .
As Chris said you don't hear of these things surging , guesstimate only but HKS may have done the cover like that knowing that heroes like to put big turbos on small engines with small AR exhaust housings . By small I mean under 2L 4's .
Not sure what you mean by "efficient boost" . Airflow makes for power and pressure just moves it along . I have been told that these wheels make their greatest efficiency at surprisingly low pressure and flow rate but the "islands" are very long meaning that they work over a wide range of flow and pressure ratio . Its a pity Garrett dont make a 76mm version of this wheel because it would be a good thing with a GT35 turbine .
Cheers .
the holes on the comp cover are a workaround for compressor surging
it allows air to enter onto the compressor wheel on the outer edge to balance out the some of intake sucking, which is commonly associated with surging. think of it as an anti surging device.
the bulk of the air enters the snout, thanks to the vacuum effect of the compressor wheel sucking in air, but a very small amount enters through the holes also to side step around surge
The ported holes are there to assist in reducing compressor surge so that the air enters the compressor housing around the compressor not through it.
They are also meant to help stabilise the shaft when at high shaft speeds to help reduce turbulance which creates vibrations.
They are there to help at a very high level of boost and if boost preasure is run outside the capacity of the compressor wheel creating surge then the vacuum effectivly bypasses the air through the comp ports and past the compressor wheel.
Also will this turbo go good on a rb25det or will there be a bit of lag, also what will
be the max efficient boost.
Depending on the size of the rear exhaust housing I have a t04z with a.81 housing and Ill be running 2bar of boost through my RB25 hopefully It will be at full boost by 4 .5 to 5000 rpm
I'm skeptical will see 2bar @ 4500rpm with a t04z... you'd need some very well matched cams and some agressive tuning to do so.
Probably closer to the 5k mark as you say.
I saw 24psi around 4200-4400rpm depending on gear/load with a GT30/.82.
However but that wasnt street fuel so it had some super angry timing numbers screwed into it... cause we could :dry:
Definately post results when your done though dude.
It'll be interesting to see vs what i had with the GT30 :D
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
