I was in a three car crash about three months ago
A cooner pulled across the road the two cars in front of me stopped but i hit the corrolla and pushed that into a pug.
Was hardly any damage to mine ofr the pug the corolla had moderate both ends.
I believed i am responsible for the whole cost, buit i have also been told that ony the rear of the car that i hit is my problem as they should have left enough room.
Any ideas,
Cheers
Wagon
https://www.sau.com.au/forums/topic/125812-crash-_/
The way I understand it is that you are only responsible for the damage you caused to the car directly in front of you.
If they ran into someone else, then they pay for that damage.
Might be best to call your insurance company and ask them - will be cleared up in no time.
https://www.sau.com.au/forums/topic/125812-crash-_/#findComment-2325099
It is my understanding that you are responsible for the whole accident if everyone else managed to stop without hitting something.
The fact that they didn't hit anything when they emergency braked means they did have enough room between cars to stop in time and the fact that you then hit them means YOU didn't.
Anyway it would be best to speak to the insurance company involved.
Cheers
https://www.sau.com.au/forums/topic/125812-crash-_/#findComment-2325126
when you say pulled across the road to you mean on a main road and the corolla went into the middle of the road?
Because there is only ment to be one car there at a time, if theres 2 its called "turning two-abreast" and it's illegal for the second car to be there.
https://www.sau.com.au/forums/topic/125812-crash-_/#findComment-2325223
i had this happen to me a few yrs ago. a bloke cut me off and run into the car that was in front of me i then run into the back of the bloke that cut me off if ya follow where im comming from . end result my insurence had to pay for the whole lot even tho there was a wittness who backed my story of been cut off .all the police said sorry mate it happens .your the last one on the line the bills yours
https://www.sau.com.au/forums/topic/125812-crash-_/#findComment-2325324
THis happened to me a few years ago too, but i was the car in front. You are responsible for the damage to both cars as long as the car in the middle had stopped before you hit them.
That is, if you pushed them into the front car, its all your fault. But if they ran into the front car first then you ran into the middle car, you are only responsible for the middle car's damage.
Well thats how the RACV saw the matter.
https://www.sau.com.au/forums/topic/125812-crash-_/#findComment-2326368
From my understanding very little will get you out of a rear end shunt where your car hits the one in front. Faulty brake lights, no signal etc are all deemed as you driving too close in all cases I have seen.
Where one car shunts another and in turn another, again my understanding and experience (not personally) is each car that hit the one in front pays. So if I have read this correctly, you wouldnt pay for the damage to the pug but to the corolla.
HTH
https://www.sau.com.au/forums/topic/125812-crash-_/#findComment-2328528
HTH
I was in a similar accident a couple of years ago. I pulled up fine, moderate braking nothing out of control like slamming on the brakes. The car behind me pulled up fine. The third car however didnt. They hit the car behind me, and pushed it into mycar. The third person was responsible for all the damage and it went through their insurance.
The simple way to look at it is, if that third car wasnt there the wouldnt have been an accident. The second car shouldnt have to pay when they hit me, because if the car behind them didnt crash into them , there was no damage caused.
If the second car had hit me, then the third car had hit the second a totally diffent outcome would occur, and it a gets a little harder to sort out.
https://www.sau.com.au/forums/topic/125812-crash-_/#findComment-2329087
Same thing happened to me yrs ago but i was the second car. My mum has a friend in insurance and from what i was told, whoever is at the rear of the 'pile up' is responsible, regardless of some wanker who can't drive cutting u off or doing illegal bs u-turns(cause of my accident). Even with eyewitness and rego num, legally you cannot prove it was the reckless driver who caused unless you got it on video (seriously how stupid is that?!). So i think you might end up brunting the cost of all the repairs on the other cars and urs. It's f*ked up but I've learned to stay as far away from ppl as possible. Never trust anyone on the road!
https://www.sau.com.au/forums/topic/125812-crash-_/#findComment-2336045
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
