and in reality 30mins of every hour is heaps. realistically you could get a clean 20 mins of ever hour. last mcgil day I went to I turned up about 11 or 12 and still did 100 laps... which is way more than enough.
  • Replies 238
Posted Images
far out
ran my car at deca on sunday
bout 20 or so laps all up
absolutely killed the brakes
the car will be useless at oran park
as a result of the day, the auto transmission feels almost dead, tailshaft f**ked, and front and rear brakes f**ked
see if i can get her going in time for op
as much as i love r31s, a stock one does have its downfalls!!
No probs then .. anyways i have placed the deposit this afternoon. And can i jus pay the balance on the day itself as per last Drive day?
J@y,
There is a form on Page 3 I think, please complete and fax off to Aaron, you can identify your payment method on that form, but yes you only need to send the remaining $100.
Thanks
Ok we have all our deposits now and here are the players
Oz R34GTR (Deposit Paid to Oz)
Ralph (Oz Work Friends) R33 GTS(Deposit Paid to Oz)
Steve (Oz Work Friends) WRX (Deposit Paid to Oz)
Alan (Oz Work Friends) RX8 (Deposit Paid to Oz)
Matt (Oz Work Friends) WRX (Deposit Paid to Oz)
Darren (Oz Work Friends) WRX (Deposit Paid to Oz)
Shane (Oz Work Friend) R32 GTS-T (Deposit Paid to Oz)
Fatz S13 silvia (Deposit Paid to SAU)
Fatz extra S13 silvia (Deposit Paid to SAU)
Yogi R32 Gtst (Deposit Paid to SAU)
Boosted 300Z (Deposit Paid to Oz)
Liz R33 Gtst (Deposit Paid to SAU)
88Silhouette R31 (Deposit Paid to SAU)
Bonks R34 GTT (Deposit Paid SAU Day)
J@Y R33 GTST (Deposit Paid SAU Day)
GTRedline R32 GTR (Deposit Paid to SAU)
Kevin XJ Jag (Deposit Paid to SAU)
Thats 17 drivers and 16 cars
This should be a good day.
Ok I think this is about our limit, I would offically say the event is full, well done and thanks to everyone, look forward to see ing you out there and having a great day.
Bugger... I just flew in from the UK and was hoping to catch this (I know its late notice). Anyway, if there are any dropouts, please let me know.
You can still make this one
http://www.skylinesaustralia.com/forums/in...howtopic=124981
Prank,
Your in if you want, no need for a deposit, just turn up on the day, I will bank on at least 1 drop out.
Abo,
GTRedline sent me a mail to say he sent someone $100, I will e-mail him to confirm.
Of those listed as having paid SAU we have no deposits for Fatz or GTRedline. The others are there.
If its gone astray I will pay on the Day Ive checked my bank a/c $100 went out 18/07 and deposit details are correct for SAU a/c
Have replied to your mail with details
C U there
I look forward to haveing a drive out there to see how your car runs!
My car? Mate, it runs like poop... I had to convince myself to take it! :P So many things on it are half finished.
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
