I've recently had a new front bar put on my r33 GTS-t & am now using new indicators I picked up from an auto store. They are much smaller than the stock ones & now causing the indicators to blink much faster due to them using less voltage (i'm guessing?).
What is the voltage of the stock indicators for 33 gts-ts? (21?) & do I need to find out what my currents ones are (maybe 5?) & buy and install a resistor to get things back to normal?
I have no idea about auto electronics, I'm just guessing? A guide down the right path would be appreciated.
Thanks! >_<
Yeap you need a resistor to simulate a ~15W load. At 12V, that means you need a ~10 ohm resistor. You'll need to find a resistor rated at 10W though or it'll be toast real fast.
Dammit. I just got back from Jaycar & bought 10Watt 100 ohm resistors. I read your post too quick, I thought it was 100 instead of 10 ohm. I haven't installed them yet. Should i bother? Will 100 ohm be way too much? Might have to go back & buy 10 Watt 10 Ohm ones?
I had the same prob ,tried the resistor thing -spent too much time and blew a few units as well . I then just bought the old school europe type flasher that isnt load resistant GREAT!!
You mean you replaced the flasher unit itself, is it a direct fit?
I have made the same mod but have just retained the original 21W globes in their holders behind the head lights. Indicators flash at the correct speed but this is a temp fix and a bit of a bandaid, the new Flasher is the go for sure.
Cheers
Luke
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
