I've recently had a new front bar put on my r33 GTS-t & am now using new indicators I picked up from an auto store. They are much smaller than the stock ones & now causing the indicators to blink much faster due to them using less voltage (i'm guessing?).
What is the voltage of the stock indicators for 33 gts-ts? (21?) & do I need to find out what my currents ones are (maybe 5?) & buy and install a resistor to get things back to normal?
I have no idea about auto electronics, I'm just guessing? A guide down the right path would be appreciated.
Thanks! >_<
Yeap you need a resistor to simulate a ~15W load. At 12V, that means you need a ~10 ohm resistor. You'll need to find a resistor rated at 10W though or it'll be toast real fast.
Dammit. I just got back from Jaycar & bought 10Watt 100 ohm resistors. I read your post too quick, I thought it was 100 instead of 10 ohm. I haven't installed them yet. Should i bother? Will 100 ohm be way too much? Might have to go back & buy 10 Watt 10 Ohm ones?
I had the same prob ,tried the resistor thing -spent too much time and blew a few units as well . I then just bought the old school europe type flasher that isnt load resistant GREAT!!
You mean you replaced the flasher unit itself, is it a direct fit?
I have made the same mod but have just retained the original 21W globes in their holders behind the head lights. Indicators flash at the correct speed but this is a temp fix and a bit of a bandaid, the new Flasher is the go for sure.
Cheers
Luke
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
