hey guys, long time no see... :yes:
was wondering if any body could point me in the right direction, i need a new diff my stock one is
very unpredictable. im in the search for KAAZ or CUSCO Mech. lsd.
i have found ended group buys and such just wondering if there is a any dealers in adelaide.
chow. :unsure:
https://www.sau.com.au/forums/topic/125874-need-a-new-diff/
yeah mate im so keen to hit the trak, previously my diff always let me down in and out of slides!
and plus it was so unpredictable and some what dangerous, you could feel the power switching between the 2 wheels on accelaration.
the diff with be in within the next couple of days so will let you guys know how it is! i have had experiance with a 2 way and am thankful this car is not my daily driver.
mm... clunky, lock and skip goodness :whistling:
https://www.sau.com.au/forums/topic/125874-need-a-new-diff/#findComment-2330387
Bl4ck32 runs a Nismo GT Pro 2 way and is on the softest setting running redline oil.
I remember there was a thread some time ago that discussed how clucky/shuddery 1.5/2ways were under slight slow cornering acceleration. It was mentioned that castrol syntheitc lsd oil pretty much shuts it up, I can't remember who it was but they too ran redline diff oil and it was fairly clunky.
It was also mentioned to set the diff tighter so it doesn't unlock so easy and clunk around, this too apparently makes it a tad more bearable.
Bl4ck32's isn't too bad but still no doubt makes him damn nervous in a car park with police around. From the out side watching Shaun drive it up on to the dyno it almost looks like a locker the way the inside wheel spins slightly but with a bit of give.
https://www.sau.com.au/forums/topic/125874-need-a-new-diff/#findComment-2330788
yeah i was going to go the 1.5 option, but this one popped up and thaugh what the hey!
i have read about different diff oils that quieten the clunky shudder, and heard that the additon of a friction modifier reduces this.
but yeah, my car is not a daily driver as such so i think i could with stand it!
https://www.sau.com.au/forums/topic/125874-need-a-new-diff/#findComment-2330837
ok guys, my diff FINALY arrived today!!
later than first expected but ohh well. it will be in this weekend!! :angry:
let us know how you guy, will be installing my nismo diff sometime in the future.
by the way jason do you by any chance know marcus with the 300zx?
https://www.sau.com.au/forums/topic/125874-need-a-new-diff/#findComment-2360313
nah, i have the old one out and the new ready to go in, was planning on putting in tonight.
BUT hows this for my day!
i had to go do a patch up job today, so the sillouete was pulling my trusty 6x4 loaded with 30 odd bricks, hopupps barra, 1/4 tonne sand cement and lime ect.....
AND MY DIFF BLEW GOING DOWN MARION ROAD!!!! it started as a slipping shudder under power/load
it slowley got worse tearing the teath off as i drove. gradually limped up flagtaff Rd. [trying to grab that 1 tooth left] and.. home!!!!
now i have to put a new diff in that TODAY as its my Daily!
ahh. :D
https://www.sau.com.au/forums/topic/125874-need-a-new-diff/#findComment-2366823
^^ u know whats funny, my mate had a similar expierence in his hsv gto le.
he too was driving down marion rd, stopped at anzac intersection, when lights went green, his car wouldnt move. lol
making wierd shuddering noise. i looked underneath n there was metal parts on the road. lol
new diff, $15k, under warranty lucky.
https://www.sau.com.au/forums/topic/125874-need-a-new-diff/#findComment-2367044
    • This might be true if you live in NZ but I can't see how this could be true for us locals here.  I've found the customer support for Haltech to be absolutely amazing. I've turned up to Haltech and spent entire days with their tech support guys, they've even helped me with wiring dramas that had nothing to do with their products.  They have the best customer support of any company I've dealt with, I can't imagine how my experiences with them could possibly be any better.
    • If you want to do a single throttle body conversion easily, you won't need to pull anything apart. Take the linkage from your throttle off the linkage controlling the ITBs. Now open the ITBs wide open, and lock the linkages in said position. Now add a single throttle body onto the front of your inlet plenum. No it's not ideal for the last nth of a kw, but it'll be a lot better than what you're already trying to do...   PS, ITBs can be so damn hard to tune from, because roughly 20% movement in a throttle body equates to a change in roughly 80% of its flow (Hence power). When you add up the flow limitations of those small throttle bodys, it is a LOT higher than that of a single large throttle. Hence, TPS is very very sensitive with them, and you do a LOT of work with sensor fusion, and some Maths behind the scenes to make those blends nice, and be smooth.
    • Yep, when Haltech purchased Adaptronic, and all of the Adaptronic staff, including Andy went with it, it took Haltech to the next level. Haltech wanted Adaptronic as they wanted things like Andy's fuel models, and some other IP, AND they wanted Andy too as he is brilliant! Andy has spoken about the incompatibilities between the old 1500 stuff vs Nexxus, and it totally makes sense. It's not JUST software that is different, there is huge changes in the underlying hardware too. It's why Haltech has had soooo many changes in the last couple of years, in terms of Hardware, and Software, and why it has become so damn Amazing. Why do you think guys like Rob Dahm with his quad rotor, went from running Adaptronic's to running Haltechs? Andy. Pretty much, Haltech these days, is Adaptronic, but with more funds behind it, and more staff, and hence Andy's visions, and visions of other people that he helps shape their great visions, into amazing new products. All the new Nexxus gear, whole new software for it, new and better dashboards, the apps that will run on headunits and NOT be slow to respond! I understand people being burnt in the past, but if you're ragging on a company, about products and issues from many years ago, it's more a reflection on yourself, not looking or keeping up with new stuff. In which case, those people should be going back to PowerFC and Nistunes as the ECU's to rave on about...
    • Right, but I thought the problem has been for a while now that even if you know manifold pressure + throttle position you still have non-linearity and aliasing issues vs actual engine load? One way I can see things simplifying is going DBW, then all air going into the engine is represented by the throttle position. As opposed to a random bimetallic strip vaguely linked to engine temperature opening and closing a shutter or some random power steering air valve suddenly allowing a bunch of bypass air. But the same throttle position/RPM at ~atmospheric MAP in different gears is not guaranteed to be same engine load? Honestly, ITBs are of such dubious value IMO. I don't know why these things are hyped up so much. The main benefit as far as I can tell is you reduce the likelihood of cross-cylinder EGR scavenging with significant cam overlap at idle. I would absolutely run speed density and be done with it if not for this fairly esoteric control problem.
    • Hah dont worry, my adult brain has this conversation every single day. Dont waste your money, invest more of it into shares, pay down the mortgage. Then the bedtime insta doom scrolling begins and after being bombarded with gtr's my mind is set: im definitely getting one! I have the current model mx5 as the weekender, but i just miss my boost and literally like your username, the sututu's that come with it. I remember with my 2nd supra, as it had twins and vvti, they used to spool real early, like 1,500rpm so you could just be a spooly boy all day long. Some people say they get over it after a while, not me tho.
