hey guys, the diff is IN!!
it's not too bad, slight shudder and skipping when turning, but thays fine, ive been in much worse!
under accelaraion the car is rock solid and feels very stable on the road. ohh and it kicks :)
chow.
  • 3 years later...
Castrol SAF-XA is supposed to be some real good stuff for the mechanical diffs. Alot cheaper than redline too.
The redline i got in mine now is pretty sheit...
Hey guys my diff in my 32 is f**ked is howling like a bitch! im still deciding on puting ina 2way or 1.5 and what brand to choose and where to take my car to get it done??? could sum 1 help me out cheers.
I for got to say that i did change the oil and that didnt stop the noise!
stick a banana peel in the housing, will stop the noise.
If its a street only car there isnt any point putting a 1.5 or 2 way in it, sure if your gonna drift or track it then go for it.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
