Hey.
Just a quick question about installing the catch can on my RB20det.
I have a aftermarket turbo and top mount manifold and the usual line which people plumb into is no longer.
Heres a quick picture of what i propose to do.
Is it correct? Is it the right breather to go off. Reason i went this one is it has had nothing on it at all since the new intake and everything had been on.
What do yous think?
https://www.sau.com.au/forums/topic/125887-rb20-catch-can/
Your intake plenum looks like a low cost option for those of us that want front mounts without the mass of intercooler plumbing.. what sort of money would a setup like that cost?? Isn't the fuel feeder/return for the injector rail mounted on the end of it? how did you get around that?
kris.
https://www.sau.com.au/forums/topic/125887-rb20-catch-can/#findComment-2324336
You can run it like you have in your diagram no worries, This is how mine has been run for 3 years and it works well.
Just need to make sure the catch can is sealed, as if it has a vented filter, you will get a massive vacum leak at idle.
Also you will need some sort of filtration in the catch can, steel wool in a stocking works well, otherwise it will not work
Alternatively you could just block of the PCV valve and run two hoses of the cam covers to a vented catch can, but I found this to be a bit smelly for everyday driving
Chris
https://www.sau.com.au/forums/topic/125887-rb20-catch-can/#findComment-2325132
Yer ive heard about putting steel wool into the catch can. it might be a bit hard with mine as the only real opening would be the drain hole down the bottom. Ill see how much i can shove into it though.
Cheers
https://www.sau.com.au/forums/topic/125887-rb20-catch-can/#findComment-2325803
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
    • Hi Luke, haven't thought about it a lot, trying to get the car into the paint shop first.  Did you want to make an offer? As stated above, I'm just looking for fair market price.
