Heya guys,
Just got an exedy 5 puk heavy duty clutch fitted - feels good!
However I've done almost 200kms since being fitted, and gave it a hit in first and it seemed to slip a bit.
It wasnt a major "kick in the guts!"
How long till you guys think you should give it 100%?
When my old clutch was slipping, when coming onto boost in 2nd, 3rd and 4th, it would slip like a mutha!
Now it doesn't do it (although I havent given it 100% throttle) but Im still abit...well...cautious you could say to!
Ive got a skid pan day sunday - just hope she's all good.
Cheers,
Chris
https://www.sau.com.au/forums/topic/125891-new-clutch-fitted/
It shouldnt really slip at all .... Take it Back and get them to Adjust it .
if its slipping its wearng and probably faster!
I just had installed similar an extreame clutch and the only running in was waiting for it to bed and not be so sharp when grabbing.
Its still a biatch in reverse but it has never slipped .....
yes there should be no major need to bed in or wear in a clutch. I would give it maybe 1-2 hours of driving (20-80kms) and 2 heat cycles before loading it up too much in 4th and 5th but after that it's as good as it's ever going to get. after 200kms it should be peak, doing 500kms to wear in a clutch is nuts. that's about 10% of it's life!
There's no adjustment in a hydraulic clutch ;)
I've thrashed evey clutch I've had from minute one, day one with no issues.
Adrian
Yeah i used the word "adjust" to take the blunt edge of they ( the workshop) may have over looked something... :)
Good luck with it MAte
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
