Hi Guys,
Can someone point me in the right direction for getting the pop up In-Dash TV for an R34, wanting to convert the 3 gauge to the Pop Up TV.
Cheers,
COATZI
Try Slizewide imports from this forum sponsor section that might supply you with pop-up tv dash as he get parts from japan.
Good luck with all this.
Hi Guys,
Cheers,
COATZI
as mention try nengun or yahoo auctions...
there is a guide on the net to hook it up so that it works with the r34 gt-t ecu
out of couriosity wouldey they work in r33 or r32 gtr
if you are running a stock ecu then yes, i belived some dude in HK, put one in his r33 gtr... but if your running an aftermarket ecu then you could just use it for a tv i guess
here is the link for wiring digram to put in other skyline r32/33
http://www.hkskylineclub.com/new/forum_pos...D=3160&PN=1
They do come in the 34GTt and it does pop up and it looks nothing like the 34gtr one. Its used as a tv and controls for the stereo. My friends parents have one in there turbo 34 in replace of the 3 gauges. It was a factory option from nissan and im sure they would be cheaper to buy then the 34 GTR version.
Cheers
Chris
^^Hi Chris,
The GTT Definatley can come with a pop up Screen and its not like the GTR at all its in car Navigation and is used as a TV screen also and cd player. Ill post up a pic! Mite be hard trying to find one 2nd hand as i have only ever seen one.
Edited by 95SKY
' date='13 Jul 2006, 10:44 PM' post='2327583']
R34 GTR MFD's work in any car irrespective of your ECU. If you can mount it and cable the sensor inputs yourself you can use it.
This thread is about the R34 GT-T/GT-V factory option popup TV set though not retrofitting a R34 MFD to a GT-T.
There are occasionally auctions for all sorts of GT-T interior pieces on Yahoo! Japan and i bet with some patience something like this could be had for well under 40,000 yen. Most likely 10,000 - 15,000 yen as I don't think there would be a huge demand for it in Japan.
Here's a search link:
R34 Interior Parts
the 'pop up in dash' i've only even seen in the GT-R, i've never seen it in a GTt. so if you want one i guess look for a place that sells R34 GT-R parts
The gtr ones and GTT ones are totaly different, I have a factory one on my mwifes GT, The gtr ones are fixed where as the gtt ones pop up out of the dash electronically and the fold away when finished. I must admit they look trick but are totally usless here in Aus as you cant convert the GPS. and you cant hook up a dvd player as there are no inputs
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
