Howdy...
I am looking to buy a turbo upgrade for my R33 GTS-t.
I currently have -
FMIC
electronic Boost control
fuel control
upgraded computer
I was just wondering what turbo would best upgrade to acheive around 250+ rwkw? And if this is possible by turbo and boost?
I do not want to spend an erractic amount but somewhere around the $1500 mark. Your help is greatly appreciated.
Also what should i look for with a turbo?
cheers
https://www.sau.com.au/forums/topic/12593-turbos/
At that $$$ you will have to look at a plain bearing turbo.
Nothing really wrong with this, just be sure that they have 360 degree thrust bearings etc. If turbine / compressor are properly sized, and oil routinely changed and not overheated you should get equitable durabilty as a BB turbo.
As for driveability and response form the plain bearing turbo i wouldnt be too concerned, im of the opinion the power and effeciancy gains of BB turbos come from turbine/ compressor design more then the ball bearing centres. They are mainly for durability.
Plain bearings can get knocked around when a large compressor is being used with a relatively small turbine due to the axial load of the shaft wanting to spin forward instead of spin centrally in the housing.
https://www.sau.com.au/forums/topic/12593-turbos/#findComment-230240
$1500 will buy you a hiflow of the stocker with plain bearings.
250rwkw a goal? Why not just phototshop a std turbo dyno run and make it 350rwkw?
Seriously what do you want the whole car to do? (a certain 1/4 time or time around your favorite circuit for example). This information can help determine the type of size that would best suit and whether the wheel should be back cut etc..
https://www.sau.com.au/forums/topic/12593-turbos/#findComment-230810
Guest INASNT
i am aiming at the same rwkw and rev i want to do consistant low 12's and be able to go sideways in 3rd gear at 100km/h :P
U will need more than $1500 to achieve your goal, i am looking at getting a custom garrett made in melbourne for around $2000, but as other said u need to change injectors, fuel pump, clutch, comp, and afm. I have budgeted about 5g for my goal.
https://www.sau.com.au/forums/topic/12593-turbos/#findComment-230860
Originally posted by INASNT
be able to go sideways in 3rd gear at 100km/h :D
Too easy. Fit a set of 205 Falken Zeix ZE502's on the back (preferably 2nd hand ones) & you'll be able to do the above with your current power level :D
https://www.sau.com.au/forums/topic/12593-turbos/#findComment-231429
Hi blx, I am a bit confused, please help me out here....
You want 250 rwkw, but you only have $1500 total?
Or you have $1500 to spend on a turbo, that is capable of 250 rwkw when you have upgraded the other parts necessary?
And your budget for those parts is?
The problem is that 250 rwkw is around 420 bhp and that is a bit over the limit of the standard injectors (370 cc's). The standard fuel pump won't even come close. I don't see cat back exhaust or dump or engine pipe on the your list of mods and they will need doing (very well). The standard airfilter will also bit a bit of problem and the inlet to the turbo will pose a restriction issue. If you want a useable power curve (not just a maximum horsepower number) an adjustable exhaust camshaft pulley is going to be required and maybe even a set of mild (around 256 degree camshafts). The clutch won't handle that sort of power and, depending on where you are located, the radiator may need upgrading and/or an oil cooler fitted.
The last time we costed a totally standard R33 GTST to a 250 rwkw R33 GTST it added up to close to $13K with minimum labour.
If you do have a little more than $1500 (not too much more) to spend on the turbo alone I would go for a hi flow of the standard turbo (GCG do ours), they are good for 250 rwkw consistently with good power curves.
Hope that helps.
https://www.sau.com.au/forums/topic/12593-turbos/#findComment-231643
Sydney kid - Thankyou for your suggestions. i didn't really take into account all of the smaller mods my car has.
Car also has - blitz air filter
3" exhaust all the way from turbo
hi flow cat
heavy duty clutch
FMIC
fuel control
upgraded computer
cheers
https://www.sau.com.au/forums/topic/12593-turbos/#findComment-231909
Guest INASNT
Originally posted by whatsisname
Too easy. Fit a set of 205 Falken Zeix ZE502's on the back (preferably 2nd hand ones) & you'll be able to do the above with your current power level :(
but that would be 2 easy man, i mean with some decent tyres on the back. :P
sydneykid
u would need an oil cooler with 250rwkw for a daily driver would u? Its not like u can all that power on public roads all day long
https://www.sau.com.au/forums/topic/12593-turbos/#findComment-231925
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
