a buddy of mine from newcastle went to wsid last night to run his r32 gtr, only having done 4 passes on the track in this car he managed a 10.8et at 123 mph.
first pass of the night was a 10.9 at 124 he said it wheel spun bad of the line and sixty footed in the high 1.6 region.
nest pass just did a launch and cruised through
next pass launched well and decided to stay into it and run the 10.8 with a high 1.5 sixty foot.
i am not sure of the spec of the car, as speaking skyline is like trying to speak spanish for me.
it has low mount turbos of some description, all factory cooler plumbing, its a built engine standard gearbox good clutch and he used TWOOGLEs tyres for last night.
he has been booted till he gets all the safety gear. so it will be a while till the time improves.
i think there is more left in it as he reports only 21 psi was used. not sure on fuel type but i know theres no gas yet.
shane
https://www.sau.com.au/forums/topic/125936-hks27l-r32-gtr-108-et-123-mph/
Yup he was afew cars infront of me last nite, that's 1 tough looking and sounding GTR.
From memory it made 415rwkw on the dyno wednesday morning and it's a 2.7L with unknown turbo's and a twin plate clutch.
I believe he has done more than 4 runs, actually he did 4 runs last nite and atleast 4 runs on another meeting I seen him at.
it made 415 kw on hills dyno, i sent him a message back saying take 30% off and the figure will be about right and the MPH backs that up some what.
all the cars i have heard about coming of hills dyno with these big figures have not been able to replicate it elsewhere or on the track with MPH.
Glens, happy with the result and feels there is more there with more driving and playing with tyre pressures.
i think theres a 10.6 in the car when fully sorted.
Awesome work on the 10.8, very efficient et for the mph well done
I think one of the GTR's from up there parked next to me aswell last time I was racing which made me move my car hahaha as I had a mate and my wife and kids coming in 2 other cars and was trying to keep each side clear for them to park next to me sorry if it seemed rude :wave:
I think one of the GTR's from up there parked next to me aswell last time I was racing which made me move my car hahaha as I had a mate and my wife and kids coming in 2 other cars and was trying to keep each side clear for them to park next to me sorry if it seemed rude :)
That was me you rude @#$*! . :laugh: I seen you and thought heres a chance to meet the Buster, then you took off. But now I know. :wave:
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
