Just out of interest for all, I've just delivered a customised version to a Perth performance workshop (Hyperdrive) last week for their drift car. Customised to measure 4 x EGTs with data logging 8 times per second - to be used when they are tuning it. This gives a good indication that this unit is not just for the streeter. Also, I am currently looking into a design of remotely mounting the LCD from the main circuit board for those people doing track work and want to have the LCD in direct view of the driver.
Do the air temp sensor probes use the same type of compression gland as the EGT thermocouple?
What sort of thermocouple to use in that sandwich plate for oil temp, can you supply?
All the thermocouples I supply are all exactly the same design (the EGT thermocouple has a higher temp range though) and use the same 1/8" BSP brass compression gland. In the first page on this thread, there is a pic of them (Thermocouple Pic). When the brass compression gland is fitted, the probe extends out 35mm past the compression gland which is sufficient exposure into any piping or sandwich plate.
  • 1 month later...
Do you have the following in stock ready for my order at this time?
In car display showing
2 x air temp (0-250), 1 x oil temp (0-250), 1 x exhaust gas temp (0-1000)
4 x 0-250 thermocouples (want an extra one)
1 x 0-1000 thermocouple
5 x 1/8" Brass Compression glands
Yes - I currently have 7 kits in stock and heaps of thermocouples & compression glands available. PM Sent to you...
  • 4 weeks later...
Sorry about that. I'm rearranging my webspace. Pics and links have been updated. Otherwise, go to http://www.mearcat.com.au/Kits for the pics and links to user manual and other kits are coming...
Yeah, I'd like to start fitting the bits now to interface to your contollers, so PM me with the kit of four sensors.
so Airbox, turbo out, Manifold in, and Exhaust gas.
lots of air temp probes!
Hey i think i saw a video of yours on youtube.Nice skid pan work.What mods do you have.Sounds like you have a bit of power.
  • 4 weeks later...
Until end of Feb, these kits will available for 15% off - a saving of $75. the full kit including the main unit and 4 thermocouples is available for $420.
Email or PM me if you are interested.
  • 3 weeks later...
sounds good will want one in a couple of weeks
Please email me your details and I will note them down so that receive the 15% discount (even if you order in early March).
-Alan
  • 5 months later...
    • 1994 Series 3 R32 GTR. Freshly built as the perfect weekender. Has many brand new Nissan OEM pieces (some you can no longer source). Last serviced (April 2024) at V Spec Performance, Melbourne, Australia. Feel free to DM me if any questions. Asking price: $190,000 AUD.  Engine RB26DETT Original 05U block Factory R32 crankshaft CP 86.5mm forged pistons Spool forged rods Factory cylinder head – rebuilt Factory valve train Factory camshafts Factory inlet manifold Factory throttle body Garrett dash -5 turbos Custom intercooler piping with Plazmaman clamps Plazamaman 100mm race intercooler Turbosmart BOV Tomei fuel rail 660cc injectors Goodridge 9000 series fuel lines with crimped fittings Stainless steel front pipes Tomei titanium exhaust with stainless steel cat converter Spit fire coils Powder coated rocket covers New Nissan coil pack emblem badge Fully repainted engine bay in Factory Black Refurbished ABS unit New Nissan brake master cylinder New Nissan brake lines New Nissan clutch master cylinder New Nissan washer bottles Custom catch can (powder coated with Goodridge lines) Steering rack rebuilt New Nissan power steering lines New Nissan AC lines A/C compressor refurbished AC condenser refurbished HPI radiator and new thermos fanes New radiator fans NOTE: All nuts, bolts, fixings new or zinc coated Driveline Factory 5 speed gear box rebuilt Xtreme twin plate clutch Stainless steel clutch line Rebuilt factory transfer case Custom one-piece tail shaft Rebuilt factory front diff Rebuilt factory rear diff Suspension HICAS deleted Bilstein dampers IKEYA formular front and rear arms and tie rod ends New bushes wherever possible Whiteline anti roll bars (underneath car only) Brakes Brembo F50 front callipers – 4 piston AP racing 380*32 front rotors, J Hook design Custom floating hat and calliper mounts Brembo 4 piston rear callipers PFC pads Stainless steel braided brake lines Body New Factory Black paint job Ceramic coated exterior panels New Nissan aluminium bonnet (super rare) New Nissan headlights (super rare) New Nissan indicators New Nissan front bar New Nissan front lower lip New Nissan head light and bonnet seals New Nissan windscreen cowling New Nissan wiper arms and wiper blades New aftermarket windscreen New Nissan windscreen seal New Nissan front doors window surrounds and seals New Nissan rear quarter windows (must replace for proper paint job) New Nissan rear window surrounds and seals New Nissan side skirts New Nissan boot badges New Nismo rear bonnet lip New Nissan guard liners Interior New Nissan lens cover over cluster New Nissan gear boot shift New Nissan gear knob New Nismo steering wheel New Nismo floor mats New Billet Handbrake lever New Nissan OEM pocket facia to replace radio Underbody Original stone guard removed and new stone guard coating applied Powder coated front and rear cross members Fuel lines painted to match factory colours Fuel tank removed, cleaned, repainted and refitted All nuts and fixings cleaned, repaired and zinc plated Wheels Rays/Volk racing TE37 18 x 10.5 + 15 in Bronze Yokahama A050 265 x 35 x 18
    • @Supernanoyour car has ended up in my hands and I was wondering if there has been any work done to the motor?
    • Sigh... yeah OEM mount rear battery, very R33, very demure, very mindful.
    • Would need a substantial current draw in the car to make a bunch of sparks. Obvs to now test resistance to ground of the car's B+ lead. If there's a short there, you'll see it. Only likely place for that, as you suspect is alternator. But there is also the possibility that rats have had a chew on some insulation. Shitbox has the battery in the boot, yeah? Plenty of cable to attack.
    • Oh, I thought of that too... I disconnected the battery and hooked up the leads direct to the car without the battery in place. Sparks... I suspect the following: Alternator has decided to kill itself Starter has decided to kill itself I'll recharge the battery, then unplug both, and go from there. The above might take 6 months - however I did buy a Victron 15 AMP trickle charger, apparently it's better than CTEK? Amazon, delivery by tonight. https://www.amazon.com.au/Victron-Battery-Charger-15-Amp-waterproof/dp/B07P4LMMMD?ref_=ast_sto_dp
