Just out of interest for all, I've just delivered a customised version to a Perth performance workshop (Hyperdrive) last week for their drift car. Customised to measure 4 x EGTs with data logging 8 times per second - to be used when they are tuning it. This gives a good indication that this unit is not just for the streeter. Also, I am currently looking into a design of remotely mounting the LCD from the main circuit board for those people doing track work and want to have the LCD in direct view of the driver.
Do the air temp sensor probes use the same type of compression gland as the EGT thermocouple?
What sort of thermocouple to use in that sandwich plate for oil temp, can you supply?
All the thermocouples I supply are all exactly the same design (the EGT thermocouple has a higher temp range though) and use the same 1/8" BSP brass compression gland. In the first page on this thread, there is a pic of them (Thermocouple Pic). When the brass compression gland is fitted, the probe extends out 35mm past the compression gland which is sufficient exposure into any piping or sandwich plate.
  • 1 month later...
Do you have the following in stock ready for my order at this time?
In car display showing
2 x air temp (0-250), 1 x oil temp (0-250), 1 x exhaust gas temp (0-1000)
4 x 0-250 thermocouples (want an extra one)
1 x 0-1000 thermocouple
5 x 1/8" Brass Compression glands
Yes - I currently have 7 kits in stock and heaps of thermocouples & compression glands available. PM Sent to you...
  • 4 weeks later...
Sorry about that. I'm rearranging my webspace. Pics and links have been updated. Otherwise, go to http://www.mearcat.com.au/Kits for the pics and links to user manual and other kits are coming...
Yeah, I'd like to start fitting the bits now to interface to your contollers, so PM me with the kit of four sensors.
so Airbox, turbo out, Manifold in, and Exhaust gas.
lots of air temp probes!
Hey i think i saw a video of yours on youtube.Nice skid pan work.What mods do you have.Sounds like you have a bit of power.
  • 4 weeks later...
Until end of Feb, these kits will available for 15% off - a saving of $75. the full kit including the main unit and 4 thermocouples is available for $420.
Email or PM me if you are interested.
  • 3 weeks later...
sounds good will want one in a couple of weeks
Please email me your details and I will note them down so that receive the 15% discount (even if you order in early March).
-Alan
  • 5 months later...
Guest
    • So, I'm not a diff swapsies specialist, but I am pretty sure the 300zx ran an R220 not and R200 like the C34 Stagea, so I think it is of no use to you. As you said, all you need to do is get the centre swapped in the diff you have, which might be best done by a diff specialist. The current centre is probably desirable to someone to track so an easy path might be to swap your mechanical centre for someone with a standard centre (which is a viscous LSD, and almost certainly won't have any limited left). The only thing you have to watch swapping R200 internals between diffs is that the number of splines on your car's stub axles has to match the donor car, or you need the centre+stub axles and make sure they have the same number and pattern of bolt holes as your rear axles.  You swap your current ratio onto the new centre so you don't have to worry about matching the front. Alternatively, centres like the Nismo pro are much gentler (and have adjustable "tightness") so you could buy on of those from somewhere like Jesse Streeter or Nengun (noting it may cost you 1234% extra in tariffs by the time it lands)
    • Id just remove the solid subframe bushes.  you are over complicating things.  on a side note make sure you do some research on the skyline shed before buying from them.
    • Just got back from overseas and once again Rego and service time. Supercheap auto cant find my plates on their list to match my car to buy a crush washer lolol. NRMA has my number plate linked to R35 GTR which i have explained once again that it is not a GTR. Its scary in the sense that if somthing happens and my insurance wont cover me if its the wrong car on their list even though they are the ones that have made the mistake. Im not sure NIGHTCRAWLER why the neg comment? Its a 2020 V37 400R Skyline? and asking for someone to post their VIN number is crazy just to prove it? Its a legit Nissan Skyline from japan factory 400R its does use the Q50 infinity chasis but this is the Japan model.
    • no, you aren't, but good to see you pop by
    • I can also smell fuel in oil if that helps.
