Hey Fellow Skyliners
My Brembo's are in need to be painted and I was wondering what is the best method.
1. Painting them myself, using VHT brake paint.
2. Sending them away to be painted professionally. Recommendations who?
Also, Would anyone know where to find the "BREMBO" stickers?
Thankyou in advanced
Intune
https://www.sau.com.au/forums/topic/126022-painting-r33-brembos/
Give then a good clean, mask the area off with newspaper and way you go. I think with brembos it should be stamped on the caliper just scrap of the paint with a knife. Use a paint pen to high light BREMBO.
Don't waste money on VHT. Looks crap after a few heat cycles on the track on my racecar, although that was a nice job on those above.
Go with the Duplicolor Metalcast. Looks too sweet. I've used it on the cam and front cover of the RB26 and the Sumitotmo calipers on one of my GTSt's and it is wonderful.
Thankyou for your replies.
JK
Your mate Brendan has done an AWESOME job and look great. Still I am unsure sure how he done the lettering "BREMBO".
Would be OK if I email him?
Cheers
intune
GTRgeoff
Would I find that paint at repco or somewhere like that?
Cheers
intune
No need to be formal here. Geoff is just fine :)
I get mine from Supercheap. Used a wire wheel on the brakes after a full brakekleen, then masked and used the silver base coat, then the crystal red top coat for a similar finish to this
Geoff
Looks fabo, did you use a clear coat?
No, the crystal red is a semi clear over silver base. I have some 2 pack top clear and that would be great but might not like the heat.
The metalcast is heat resistant and brake dust doesn't stick so stay crystal red.
You can get purple and some other hideous colour but the red is good for me.
Thankyou for your help.
will try this weekend.
I repainted my a while ago exactly the same. The stencil I had made by a sign shop. I can send you the Brembo artwork and then simply give them the file and tell them that you are wanting a stencil for painting. I did find a stencil kit you can buy, however that was out of the UK. Painted mine using VHT black with silver "Brembo". Went over it all with a high temp clear coat however the clear coat perishes every time I go on the track so I simply wiped it all off. VCHT has been great ever since.
you need the stencils to do the calipers..... i have it if anyone needs....also 2 pack clear is more than strong enough for the application....i dont know why you guys think that single pack paint would be more durable than 2 pack
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
