Armourall extreme tyre shine. It doesnt stick on the tyre properly, consequensly it flies off the tyre and will go around the guards and when you wash the car the paintwork will go all specaly. My cars black so it wasnt too bad, but its damaged the paintwork (cut and polish should fix it) but it shouldnt have happened in the first place.
https://www.sau.com.au/forums/topic/12603-avoid-this-product/
I use a product called '303 Aerospace Protectant' - absolutely brilliant on all rubber and plastic, UV resistant and really brings plastics back from the dead.
A boring fact is it was developed for NASA for use on plastics on satellites or some such thing :P
http://www.303products.com
Only know of two places in perth that sell it really though, which is a bummer. Harder to get hold of then some of the Meguiars products :D
yeah, the foaming armourall is the one I use, never had a problem with it... except if you get some on the rims and havent cleaned them yet, cos it partly cleans them and leaves a bit of a streak... but if the last thing you do when you clean your car is the tyres, then it's not a problem.... Like Psiko said, it's not a black coat, it's a tyre cleaner....
I dont want to seem pedantic, but why is it we can tell people to avoid products of certain companies, while threads mentioning bad things about tuning shops and the like are locked in a matter of minutes?
Are larger corporations allowed to be criticised?
If thats the case id like to take issue with:
Microsoft
Exxon
Enron
Worldcom
Mayne Group
Stern Lecture Plumbing
Thankyou. :P
Red17
Just a general heads-up about this product. It seems, from what most people say, this is common of other tyre shine products. I think thats acceptable. I didnt go all out and critisise the company or product, I didnt "bad mouth" them. Armourall have agreed to refund my purchase and I'm happy about that. I've used their other tyre shine product, which can also be used on your dash/interior, on my tyres and it worked great, so I thought I'd give this one a try.
Kiwi shoe polish works fine for me ........... !!!!
Hey guys, why's everyone so touchy in WA at the moment? I've been reading and watching for a coupla months before I felt I could offer anything sensible. And in that time, it all seems to have gone down a coupla notches in quality, with people sniping at each other. Is there too much iron in the water or something?
Cheers.
P.S. OK - sorry - off topic, I know. Mea Culpa.
The tyre has to be f#cken clean first, and your suppose to wipe off any excess. If you drive off with the tyre dripping with tyre shine what do expect??
Buy the pressure pack ones, turtle wax one or the......... cant remember the name, comes in a blue can. Good shit anyway.
Or you could go to a bike shop and buy "Super Motorcycle Shine". Sounds gay, works fuggen brilliantly! Between that and "Plexus", my bike comes up a million dollars, and it works well on cars too ... it just takes longer thanks to being about five times bigger :D
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
    • He means "as opposed to mechanical cable drive". Older cars (R32 for ex.) had cable drive. Later cars with essentially the same gearbox, ie R34 GT (NA RB25) used essentially the same box as the R32 GTSt, but instead of a cable drive, had an electronic speed sender plugged into the same hole in the box, running from the same little gear that would have run the cable. Some of the shittier later cars use a speed sender on the nose of the diff, or the ABS sensors.
    • Lower than engine, or lower than it should at the hubs? Either way, that is a nice power figure and I'm not surprised you say it rips now. What stopped you from turning it up any more? Injectors? Or did it just stop responding to boost?
