As long as it doesnt damage my turbo in the long run then good :( , so if i do tighten the bov this wont happen anymore???
Im not quite sure how yours works but I think you would want to loosen it, dont loosen it so much that it leaks at idle though, ultimately youd want a really small amount of flutter at very low boost 3psi etc. That way you can be certain its not leaking vacuum at idle. Just play with it until it sounds right, its not going to do any damage either way, worst case itll pop and wont idle properly because its too loose and leaking.
LOL
Guys do you just make up shit for fun, the compressor spinning backwards? c'mon if you dont know anything about it dont say anything, all it does is propogate misinformation.
The air will just escape between the blades slowling minimally, thats why it makes the chopping flutter sound, if it stopped the compressor completely or pushed it backwards or whatever it would sound just like a bov cause the air wouldnt be getting chopped up.
The flutter does sound fully sick though, my stock redtop rb20det R31 fluttered like crazy, they came out stock with no bov.
sorry, i didnt word it very well. i didnt mean that the compress will spin backwards, but the wheel is forced towards the turbine wheel. if you were looking at the intake, it would be forced backwards.
oh and as for the slowing of the blades and pushing it back, it wouldnt just sound like a normal BOV, from my understanding, the pressure builds up, causes the comp wheel to slow down, force it back a bit, then this relieves the pressure, and comp wheel will speed up again, comp wheel will come back into place, then the pressure builds up again and so on
Edited by VB-
The fluttering noise only happens when i dont push her full throttle, i think it is compressor surge...
Ok thanks for all the help guys, i have noticed that she will stall sometimes on down gearing and when i rev her on idle or hunt so ill have a play with the bov, so losening is the best solution?
Its 100% not compressor surge. The GT35r .82 on an RB30 won't experience compressor surge unless you some how manage to get it making 1bar at 2500rpm. :)
RE: The stalling.... Atmo bov, try playing with the off throttle fuel cut I showed u last time, bump it up a little higher. I don't believe shaun would have done this as he would have loaded another map in to it erasing what you already have. :)
So what your saying is the compressor/shaft has slack in it causing it to move backwards and forwards? surely itd break pretty quickly if that was the case? do you have anything to back that up?
shaft owuldnt have slack in it. when you say backwards and forwrds, do you mean rotation wise? or laterally, from compressor to exhaust turbine? no i dont have anything to back this up, its what i was taught, and i believe it, to me it makes sense.
you tell me?
I didnt understand what you were saying, I figured the air just came back out the inlet getting chopped up by the turbine as it wouldnt be spinning with it causes a pulse of air which sounds like the flutter you hear.
i always thought that it was a build up of pressure, coz the compressor is still spinning wen u back off the throttle, and still forcing more air in, and the air trying to escape is met with heaps more air being forced in, then the pressure builds up to much and slows the compressor while the pressurised air escapes, then when the pressure drops, more air is still fed in by the compressor, pressure builds up again, and slows the compressor and goes through it all again.
kinda like the overboost valve on idny cars, except its just going back through the turbo rather than a valve if u get me? pressure builds up to much, it gets released, and then when the pressure drops, the valve closes (the turbos compressor is spinning at speed, forcing air in while there is lower pressure in the inlet piping/coller etc) this is a sh*tty example but its the only thing i could think of to give you an idea of what i mean
lol im not good at explaining things, but i do try :) aint that worth sumthin?
From what ive been told, the flutter has NOTHING to do with your bov.
its actually the noise of the waste gate opeing and closing really fast.
i was told it has somthing to do with the pressure difference in the plenum and the differnt pressure in the cooler pipes.
Whether the spring is loose as it can be, or tight as can be it will still make the flutter.
also when i installed my fmic, i didnt have a nipple on the cooler pipes so i used the vacum line running to the bov to run the vacum line was attached to the cooler, after that it started fluttering like crazy, and i was told as the vacum line running to the wastegate is now longer, the gate opens and closes continuously when you back off the throttle.
Meh everyone has their own theory about what causes it.
Did you even read the thread? its not the f**king wastegate opening and closing, everyone doesnt have their own theory, people just spout bullshit over and over again. It is clear what is happening and why it happens and its been said several times in this thread.
Man im sick of people.
edit: http://ausrotary.dntinternet.com/forums/vi...bov&start=0
read this thread, namely the posts by riceracing, he knows his stuff, I think he is on these forums as well. Theres more information regarding flutter there then anywhere.
Edited by Rolls
Well hasn't some one been pissing in your ear.. ;)
lol @ Rolls... :D
So anyone want to make a good summary on why the fluttering noise happens, if it causes any turbo problems even later on down the track and if so whats the best way to combant the issue? I havent had a chance yet to adjust my bov as my bonnet is cable tied shut ;)
So anyone want to make a good summary on why the fluttering noise happens, if it causes any turbo problems even later on down the track and if so whats the best way to combant the issue? I havent had a chance yet to adjust my bov as my bonnet is cable tied shut :P
That ausrotary thread and the one earlier from here are good discussions to read. No one has really prove either way it will or wont damage your turbo, so its really up to you to make your own decision on what you think.
Personally I dont think you are likely to see any damage as alot of cars back in the 80s were fitted stock without bovs (R31s/DR30s etc and the VL turbos) and managed to see 80kms before they were required to service their turbos. The maintanance intervals are now more like 120kms but whether this is from the fitting of a recirc bov or just because they are manafactured better you dont know.
Why the fluttering happens? because when you dont have a bov or it is so tight it doesnt open properly the compressed air has to go somewhere as the butterfly is closed. Now normally it'd go out of the bov but instead it moves backwards back through the compressor wheel getting chopped up as it slides past the blades (still spinning) then back out your pod filter. If you have a big intercooler it will bounce around and amplify the sound even more. All this talk about wastegates is complete non sense and has nothing to do with it. If you can be bothere searching theres about 10 other threads about this that explain it fairly similarly
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
