Here's my input to the archives after taking so, so much...
CAR: 1990 R32 GTS-t
PARTS REQUIRED:
1x clutch master cylinder assy. I bought mine from Kudos Motors Sorts as Genuine Nissan Part.
1x bottle of mineral brake (and clutch) fluid. Do not use Synthetic stuff as I’ve heard it destroys the seals in the master cylinder, making the whole problem occur again. I used Penrite brake fluid. Good stuff.
TOOLS REQUIRED:
12mm and 10mm spanners
Small to medium sized adjustable shifter
12mm socket and ratchet
Pliers
Bucket/Oil pan
Jack and chocking/support bricks/ramps
Optional: large spring assisted pliers (not sure what it is actually called).
Time - give yourself about 2 hours if you haven't done it before
Difficulty - Perfect for the DIY'er. about a 5/10. Keep in mind that if you stuff it up, you're not going to be able to move your car. Hence, leave your car in a position where it can be towed easily or that your not blocking the drive way off!
Step 1 - Drain the fluid from the master cylinder. Jack the car up from the driver’s side. Look underneath the car to find the clutch slave cylinder. There will be a bleed valve there identical to the one on the clutch master. Use your adjustable shifter to undo the bolt enough until fluid comes out. Collect it in your pan. After it has stopped dripping, push and pull the clutch in and out a couple of times just to make sure the old fluid is out. The clutch pedal will hit the floor so don't panic. Lower the can back down, but not completely off the jack, just enough for the tires to be firmly on the ground.
Step 2 - Push the driver’s seat back (or take it out if you are not flexible enough). Look upwards at the clutch pedal to find a bolt and pin. This attaches the master cylinder to the clutch pedal. Rotate the pin around until as much of it shows clear of the pedal so you can get your pliers and yank it off. It won't give you too much trouble. Then slide the bolt out (horizontally). This will free the clutch pedal from the master cylinder.
Step 3 - There are two bolts attaching the master cylinder to the firewall. Use your 12mm tools to get these off. I found removing the pipe leading to the AAC valve will allow some manoeuvring space for your hands.
Step 4 - attempt to remove the steel pipe leading from the clutch master downwards. I was unable to use my 10mm spanner effectively as it would just round. If you can get it off, skip step 5 and 6.
Step 5 - Back underneath the car with your 10mm spanner. Find the steel line which leads from the master cylinder to the slave cylinder. It leads to a conjunction box which is flimsily mounted to the car. The pipe should end on the side of the rear of the car, facing forward. Undo this bolt which attaches the line to the box and move the line out and around the other return line which is present there.
At this point you will be able to remove the master unit from the car with a bit of manoeuvring for the line. Do not allow the steel pipe to bend, with the right bending and a bit of patience, it will be removed easily.
Step 6 – take your spring assisted pliers (or anything with enough clamping force) and clamp the 10mm bolt. Use the body of the master cylinder to free the steel line. After freeing the line, carefully place the line back in its position within and around the other lines of the car. Do not force it, the line must go around the speedo cable and other things properly, and it will. Bolt it back up to the flimsily box near the clutch slave cylinder.
CAUTION: brake/clutch fluid is extremely deadly for paint. Watch out when you remove the line, because there will be some left over in that line.
Step 7: Almost there. After the steel line is back in place, manoeuvre the new clutch master cylinder in place of the old one. Attempt to connect the steel line back up to it. I found this too difficult to do as the angle needed to be perfect, so I removed the steel line back off, connected it to the master cylinder and then put the whole lot back in as a whole.
Step 8: Bolt the 12mm bolts back up and then connect the clutch pedal to the new master cylinder. That pin can just be pushed back on by hand.
Step 9: Jack the car back up and get underneath it. Use your shifter to tighten up the drain bolt back up. Add new brake fluid to the cylinder. Watch some of the Air escape. Make sure all connections are tight and not leaking.
Step 10: The Bleeding Process. This is the final step and if you’ve come this far, the hard part is definitely over. Throughout this process, you will have to gradually add fluid to the master cylinder. Do not let the level of fluid sink lower than ¾ of the level in the chamber.
After adding the initial fluid and observing some air escape, go back down underneath the car to the slave cylinder valve, open it, you should see air bubbles escaping followed by the new fluid, allow this to run briefly so that any old fluid can escape. Tighten up the slave cylinder again, then top up the fluid in the master.
Open the bleed valve on the master cylinder now and allow fluid to escape from there too. Tighten it up. Top up the fluid once more if you have to. Now all connections should be tight. Push the clutch pedal in and out with your hand 3 or 4 times and then go back underneath the car and open up the slave cylinder again, allow fluid to escape and then close. Repeat this process another 2 times. Always make sure you have enough fluid in the master cylinder.
That’s it. Congratulations.
If anyone thinks I have left something out, post it up and i might amend the write up. There may be better ways of doing things, but this is what I did yesterday, and now my clutch feels excellent. I might try and do some pictures if people tell me they need them.
Edited by SuAvE-1
  • 6 months later...
  • 2 years later...
  • 5 weeks later...
  • 4 weeks later...
when is this needed?? When there is a sign of leakage??
when you clutch in to change up/down a gear, you hear a noise followed by your clutch pedal hitting the floor your ability to select gears goes out the window and your stuck in some random area. -.- just experienced this earlier today. bunny hopped it in gear to get it going and 1st geared it all the way home :rofl:
  • 4 months later...
Is anyone aware of the differences between this and a gt-r install? In particular I have an R32 early gt-r gearbox with a gts-4 master. What replacement would be the best option?
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
