Definately alot better than the one that was in there... took a bit to get used to... like making it not chirp when down shifting and to make the changes smoother with ur day to day type driving... but it grabs HARD :P
exedy HD racing clutch... ownz0r! :D
thanks to benny and max for installing it... and thanks for the good price too :D
https://www.sau.com.au/forums/topic/12605-new-clutch-is-in/
750 installed... no idea on the power rating... but it holds what i have right now very well... and someone else i know has the non racing clutch version and has 200rwkw and hasnt had an issue
https://www.sau.com.au/forums/topic/12605-new-clutch-is-in/#findComment-230882
aaaw i want one for 250... lol nah im happy with the price i paid.
tossing up wether or not the cooler is going to go on next month or not.... stainless and silicon hoses for 550.... hard to pass up.
also want a quote on 3" stainless dump and front pipe...
https://www.sau.com.au/forums/topic/12605-new-clutch-is-in/#findComment-246586
  Quote
Originally posted by poyz
One of my biggest peeves...
Clutch's are measure on how much power they can hold.
It's how much bloody TORQUE, dammit.
u'll get over it... if not... kleenex?
doc - damn... and here i was thinking it might be closer to this end of town :D
omg i just looked Heidelberg up... ITS MILES AWAY! its woop woop!!!
https://www.sau.com.au/forums/topic/12605-new-clutch-is-in/#findComment-251098
the clutch makes a lot of difrence eyy
man i notcierd alot from my old one to th eone i have now
it feels alot better and when changing it grips and launches threw every gear
and does demos into 2nd and into 3rd and on cold nites i get a lil squak into 4th!!!
ahh shit thats y 4th went!!!
https://www.sau.com.au/forums/topic/12605-new-clutch-is-in/#findComment-252200
pfft sif... its like close... to me :P
man heidelburg is surrounded by BUSH! i seen it on the map... all that green stuff... and rivers... and kangaroos and paddle pop lions.
omg it will take me like an hour or more to get there.... cant i just drop it off at bennys house? its 2 mins away! :P
https://www.sau.com.au/forums/topic/12605-new-clutch-is-in/#findComment-252316
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
