GTR_Legend Posted July 13, 2006 Share Posted July 13, 2006 Guys, Have had a major service and hada hicas lock bar put in. Over the last couple of days i have started to hear a knock from the back of the car when driving, sounds like somthing swinging in the fuel tank as its not constant but not sure, will have to have a look on the weekend. Just want to see if any one has had an issue like this and what it was? cheers, Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/ Share on other sites More sharing options...
sh@un Posted July 13, 2006 Share Posted July 13, 2006 First thing I would check is the exhaust- Specifically, make sure the mounts are still secure, or have a look at the clearance the tie-rod has with the exhaust while the car is on the ground now that the hicas set-up has been modified. Whoever installed it may have messed with the exhaust hangers or something in that area. You've gotta use pry bars 'n shit to do work on that stuff. It's tight in there too, with a decent sized 'zorst. Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2328063 Share on other sites More sharing options...
GTR_Legend Posted July 13, 2006 Author Share Posted July 13, 2006 when i got the major service i also got a high flow cat and 3" front pipe! mmmm!!!! Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2328072 Share on other sites More sharing options...
GTR_Legend Posted July 14, 2006 Author Share Posted July 14, 2006 F@CK Just drove from the city back to work and its heaps worse now. Seems to be a constant knock when i decelarate, think it could be a diff/driveshaft issue? Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2329537 Share on other sites More sharing options...
Craved Posted July 14, 2006 Share Posted July 14, 2006 jack the car up, have it in gear and try to turn the wheels suddenly.. see if it makes that sound.. that will discover if its drive line related MAKE sure the handbrake is off for this one, also try it out of gear aswell also while its up.. shake the exhaust to see if it moves enough to make that noise Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2329700 Share on other sites More sharing options...
GTR_Legend Posted July 14, 2006 Author Share Posted July 14, 2006 cant jack it up yet but just had a look at the axles, the left one has some play in it, i can move it back and forward The above is normal operation Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2329710 Share on other sites More sharing options...
Craved Posted July 14, 2006 Share Posted July 14, 2006 (edited) is it only this one that does it? edit - that doesn't explain why noise is only on deceleration though Edited July 14, 2006 by Craved Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2329749 Share on other sites More sharing options...
MerlinTheHapyPig Posted July 16, 2006 Share Posted July 16, 2006 take it back to mechanic who did service. let them figure it out. it sounds like it could be some part of the exhaust hitting, maybe the tailshaft or one of the driveshafts. That happened to a friends silvia. I think flange on cat was hitting tailshaft. Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2332395 Share on other sites More sharing options...
qikstagea Posted July 16, 2006 Share Posted July 16, 2006 on deceleration there is no positive force/pressure on the axles. they are spinning loosely, really. Same as why i was getting diff chatter on deceleration and constant speed, but never under load. Just see if you can get it on a hoist, and anything that moves, move it. Turn it. Shake it. Process of elimination. Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2332399 Share on other sites More sharing options...
hefer81 Posted July 17, 2006 Share Posted July 17, 2006 on deceleration there is no positive force/pressure on the axles. they are spinning loosely, really. Same as why i was getting diff chatter on deceleration and constant speed, but never under load.Just see if you can get it on a hoist, and anything that moves, move it. Turn it. Shake it. Process of elimination. Check to see if the handbrake cable hasnt come of its bracket as this can occur hitting the tailshaft Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2335029 Share on other sites More sharing options...
GTR_Legend Posted July 17, 2006 Author Share Posted July 17, 2006 Farkin bad!!!! Both rear tyres had loose nuts, (were not tightened after service just over 1 week ago). Lost one nut, another 5/10 k's the wheels would have fallen off. I didn't even check the wheels at first as it is something simple i thought the workshop would have tightened! Called and expressed my feelings.... Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2335248 Share on other sites More sharing options...
Duncan Posted July 17, 2006 Share Posted July 17, 2006 knocking wheel nuts....they sound sounds *really* bad don't they? nasty too, we had a wheel come off and break 2 studs at targa one year Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2335393 Share on other sites More sharing options...
racsov500 Posted July 18, 2006 Share Posted July 18, 2006 nasty bet someone got a strong lecture at that workshop! Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2336667 Share on other sites More sharing options...
GTR_Legend Posted July 18, 2006 Author Share Posted July 18, 2006 nastybet someone got a strong lecture at that workshop! Link to comment https://www.sau.com.au/forums/topic/126055-knock-knock/#findComment-2336878 Share on other sites More sharing options...
