We didn't see any last Friday night, but they've been out there before, either just a drive through or they'll stop & have a bit of a look at err, people's stuff.
They usually turn up if someone's being a tool
well i'll be out tonight, my brother is coming down in his Chaser (got back from europe on wed), so we'll make an appearance. if no one goes to the museum, look out for a silver madwagon (Stagea) and a pearl TRD Chaser
waitaminute - is the chaser a creamy colour?? with nice rims and big zorst?
I think the creamy coloured one you guys are talking about lives in belconnen, I use to live on the same street as him till the end of last year. There's also a black one running around town sitting on 20s.
dunno where you were, wasn't raining anywhere in civic while i was out. stayed at the museum for about half an hour and no one showed up until i was leaving, and that was just Frink.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
