hi,
thanks too all you all i have found some faith in my car again. its not that i dont like skylines i just find my gtr a little incnsistant to my prevoius cars.(300zx and soarer)
but as written in todays sunday telegraph (quite funny story on street racing) all street racers aspire to own the mighty godzilla the gtr :laughing-smiley-014:
"Police use a variety of vehicles to detect street racing and other offences,'' he said. ``This includes covert vehicles equipped with video recording systems, as well as vehicles sourced from outside the NSW Police fleet.''
Ive seen a P plated XR6T undercover cop car.
Dont put anything past em! confiscated cars get drafted in too... dont overlook anything.
I'll be hanging home tonight, apparently some big crackdown on 'racers' and what not. Heard it on the radio and have heard it from a few other people.
pfft.. they always say that..
just dont do anyhting stupid infront of em.
They cant stop you from driving on a fri night
As suggested by Bluprint (Mark) and Baconer (Alex) - After the meetup at Woden and Museum we could cruise to Mt Ainslie for a group photo. You can see a great sample photo in the "night time photo shoot" thread as posted by Bluprint.
http://www.skylinesaustralia.com/forums/in...80125&st=20
only thing is that it can get pretty busy up there at night, so there might not be enough parking, but you never know if you never go....
Sounds like you're a regular up there Luke, somethin we should know about?? :) Don't tell me you've been borrowing Michele's whistle......
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
