So is this still on for tonight? 8:30 at futsal or earlier? later?
Yes, its still on and we're planning on meeting at 8:30pm tonight at futsal - for those who are not sure where it is, see the marques in the park thread for the map of where we met opposite Floriade.
I don't know that I've told everyone the results of the photo competition - Mark (Tuk Tuk) came second with this photo
What you don't pick up in that pic is that although he looks further away, with the wide agle lens, he is only about 12" away from the subject, there was a lot of trust required on both sides.
Are we ready for the photo shoot?
Blueprint
R33Driftr
CeJay
unSteddy
micky_tee
Shell
Tourismo
RB20tR32 - you can still come if you change your mind.
Its not too late if anyone wants to join us.
A friendly word of warning to those traveling to the museum tonight, We have the Erindale Collage Formal on tonight, and to give you an indication, We (security) kicked out St Claires Formal last night for various reasons.
Lots of police were around the museum from 6pm till very late in the evening.
Several Cars were impounded or towed away.
Otherwise, If I get a chance I'll come down and say hello
J
You (security)... Thats not nice kickin people out.. haha
yea i just come on to warn you.. im doin a drop off to the formal.. and yea at museum.. drop off if from 6-630... even if you do get there later, im sure there will be a bit goin on when it finishes..
Reece is in town at the moment and says its raining
What would people like to do? Want to go to Civic under ground carpark? bottom level?
Or would people prefer to keep their cars shite and briny?
okay, it appears as if under the bridge is covered with Elton goers. The rain is causing some problems... although I like the wet ground look, so if the rain stopped it could still be good.
Mark is going to meet Tourismo/Reece at Top of Tuggers multi level carpark in about an hour to test some pics - All are welcome to swing by, although if its pouring rain, they will retreat to the next level down.
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
