so did you not get the new one put in??? i thought you dropped it off at trojan to have a new one dropped in??? and do you know where the meet point is??? there was to many different places being passed around im confused as to which it actually is
Well I enjoyed my first SAU meet at Regatta point. Not a massive turn out, but still good so see some people willing enough to freeze there asses off to come out.
that would NOT be me :down:
I hope it's warm for tomorrow's cruise...
under cover carpark how do you get there, drive round up to the front drive past then down undernearth???
i know that the belconnon mall carpark is open late at night, no charge and undercover, (but is a bit out of the way), they open late for movies
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
