Hi Guys, I am having an issue with my idle...
When I come to the lights, the revs will sit at 1500rpm for about 5 secs or so and then drop down to around 900rpm... It's annoying me!!
I have cleaned the AFM, Re-soldered the internales of the AFM and cleaned the ACC valve. I have also checked vaccume hoses ect and can't find anything.
The only thing that I can now think of is the O2 sensor (I have recently replaced the stock dump with a 3" jobbie).
Where do I get one from? Can I just use a universal one or is it the same as the VL turbo??
Can anyone suggest what else it may be?
Thanks all!
Todd
https://www.sau.com.au/forums/topic/126058-o2-sensor-idle-problem/
more info needed. car, motor? i know that you can buy a NGK sensor for about $110 for the rb25det, and the rb20det. i don't know if they are the same plug. i gather that the non turbo would be the same, but not 100% sure on that. but the sensor for the rb25det is the same as a SSS pulsar (sr20 motor).
but my old SSS pulsar does the same thing when you stop though. what is your fuel economy like?
Thanks mate...
R32 GTS-t (RB20det).
Mods:
FMIC
EBC
Dr Drift remap and tune
3" Ex + Dump
Pod
R34 Turbo
Irridum Plugs
Bosch 040 Fuel Pump
I do a bit of highway driving to and from work and generally get 350-400km's to a tank...
I have recently replaced my coils due to missfiring, and as I said have done the AFM and ACC valve.
In my mind this is the next step? Would you agree?
it really comes down to the map that the ecu is running on. you may change the o2 sensor and have it still do it. its a fair bit of money to get rid of it. come to think of it i think my car does it (r33). i will check over the weekend. i know it used to do it, but i haven't taken much notice for a while. i did replace my o2 sensor a while back (trying to get better fuel economy). didn't make a difference to fuel economy. i'm about 90% sure it used to do it, but i'm not sure if it still does.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
