Flying Performance International is the only official online Hybrid & SABER dealer
Flying Performance International official website www.flyn.com.au
Check out the Hybrid & SABER official website at www.powerdigger.com
FLYING PERFORMANCE 3" DUMP AND ENGINE FRONT PIPE IN ONE, because it is a Flying 3" mandrel bent dump & front pipe in 1, not just the front pipe that other people sell, WE GUARANTEE MASSIVE POWER INCREASE OF UP TO 50 PS!!! If you have a boost gauge you can see the 2-4psi improvement and the better throttle responsiveness. VERY LIMITED STOCKS! HURRY!!!
We have the following models available:
s13 / 180sx ca18det
s13 / 180sx sr20det
200sx s14 / s14a / s15
r32 2.0L gtst / gtsr
r32 2.5L gtst / gtsr
r33 gtst / gtsr
$225 delivered
OPTIONAL PACK
FLYING PERFORMANCE NEW 6 METERS HEAT SHIELD EXHAUST WRAP KIT INCLUDING STAINLESS STEEL RACING CLAMPS $35
This pipe will give you 2 - 4psi increase depending on existing boost pressure.
Payment Instruction
Postage & Handling = $15 freight Australia wide
PAYMENT TO : FLYING PERFORMANCE INTERNATIONAL PTY LTD
ST. GEORGE BANK LIMITED
BRANCH NO. : 112-879
ACCOUNT NO. : 065766824
PLEASE you must give the bank your forum user name as the description of the transaction. That way it shows up on our bank statement with the amount you have sent us. So we can match your order with your payment otherwise there may be a delay for us to match the payment to your order!
After you have made the payment, please you must e-mail us with your payment date & amount, your name & postal details.
Once we receive your payment, we will inform you and send it at the same time.
It will be packed and sent securely in boxes or bubble padded bags for best protection.
Optional extra
7f_1.JPG $48 SABER stainless steel mesh air filter
41_1.JPG $180 SABER 60mm electonic smokey lens gauges
59_1.JPG $259 SABER GDB WRX /STi air intake kit
cf_1_b.JPG $49 HYBRID a set of 10 HOSE CLAMPS, 2.5", 2.75" & 3"
f0_1_b.JPG $19 HYBRID SILICONE HOSE REDUCER, We have 3" - 2.75" / 3" - 2.5" / 2.75" - 2.5", you tell us the size you want.
0a_1_b.JPG $17 HYBRID SILICONE HOSE, 3" / 2.75" / 2.5" / 2.25" / 2" / 1.5" STRAIGHT HOSES
53_1.JPG $7 FLYING SILICONE VACUUM HOSE
12_1.JPG67_1_b.JPG $49 Flying bov
05_1_b.JPG $49 Flying boost controller
7b_1_b.JPG $29 Flying boost controller
5c_1_b.JPG $199 + $25 extra freight
4e_1.JPG $33 FLYING 6 meters EXHAUST HEAT WRAP
06_1.JPG $149 Flying sr20det turbo manifold (SOLD OUT)
0a_1.JPG $189 Flying Rb20det / rb25det turbo manifold
dd_1.JPG $149 Flying 180sx s13 r32 300zx camber arm
e3_1.JPG $149 Flying s14 s15 r33 r34 camber arm
b8_1.JPG $139 Flying GT wing
72_1.JPG $99 Bee*R PINAPPLE BUSHES S13 180SX S14 S15 R32 R33 R34 Z32
5d_1.JPG $75 FLYING S13 180SX S14 SR20DET SILVIA SHORT SHIFTER
26_1.JPG $79 FLYING SILVIA S13 180SX S14 S15 SR20DET TURBO DUMP PIPE
fe_1.JPG $99 FLYING SKYLINE R32 R33 R34 RB20 RB25DET TURBO DUMP PIPE
55_1.JPG $55 FLYING ADJUSTABLE FUEL REGULATOR
7b_1.JPG $25 FLYING OIL CATCH CAN
HSD Suspension
HSD coil-overs are used by 2005 Drift Australia champion Darren Appleton and many other prominent drivers in Australia. Now available only in the premium HR series, HSD coil-overs feature 55mm heavy-duty full-tapped dampers with 15-step damping adjustment. All models feature pillow-ball top mounts for easy installation and maximum control. Models with strut-type suspension also feature camber adjustment, while all models feature adjustable base height and spring seat height.
HSD coil-overs are supplied with spring rates intended for club-level motorsport, drift and street driving. Harder or softer springs are also available at just $100 a pair. All rates from 3kg/mm to 14kg/mm are kept in stock.
All HSD coil-overs come with a 12-month warranty against manufacturing defects.
NISSAN
S13 Silvia or 180SX $1549
S14 200SX $1549
S15 200SX or Silvia $1549
R32 Skyline GTS & GTS-t (GTS-4 available to order) $1549
R33 Skyline GTS25 and GTS25t $1549
R34 Skyline GT and GT-t $1549
R32 GT-R $1549
R33 GT-R $1549
R34 GT-R $1549
Z32 300ZX and Fairlady Z $1549
Z33 350Z $1549
TOYOTA
JZX90 Mark II, Cresta, Chaser $1549
JZX100 Mark II, Cresta, Chaser $1549
JZA70 Supra (Also GA-70, MA70, MA71) $1549
JZA80 Supra $1549
SXE10 Altezza and Lexus IS200 **NEW** $1549
SUBARU
GC8 Impreza WRX (MY94 to MY00) $1599
GDB Impreza WRX (MY01 to MY02) $1599
GDB Impreza WRX (MY04 on) $1599
SG5 Forester $1599
MAZDA
FC3S RX-7 (Series IV and V) $1549
FD3S RX-7 (Series VI to VIII) $1549
MITSUBISHI
CP9A Lancer Evolution (IV to VI) $1549
CT9A Lancer Evolution (VII on) $1549
HONDA
EG Civic $1549
EK Civic $1549
DC2 Integra $1549
DC5 Integra **NEW** $1599
AP1 S2000 $1549
Edited by [FLYN]
This wrap will work on any make or model of cars, if you can wrap it you can use it! This wrap can even eliminate turbo lag!
You have seen it in proper race cars like V8 Supercars and JGTC in Japan, and now we bring it to the street, introducing the FLYING Exhaust Fiberglass Wrap. It is a weave of the finest insulating fiberglass material with extremely closed texture pattern. The type of fiberglass we are using to make the Exhaust Wrap is carefully examined and tested in our overseas development centre to ensure it will last over the vehicle's working life for reliability and durability. It keeps the heat in the pipe and at the same time protects the electronic components in the engine bay.
The wrap is about 2.5 millimeters thick and 1.8 inches wide, can withstand temperature of up to 600 degrees Celsius which is something that the HPC won't be able to offer. Keeping exhaust heat inside your exhaust pipes maintains exhaust gas velocity, helps to increase combustion scavenging and thus increases power. FLYING Exhaust Fiberglass Wrap can also reduce under bonnet temperatures as much as 80% by insulating both fuel and clutch lines, while protecting mechanics and other electronic components in the engine bay from injury. For example, 6 meters long is enough to wrap a 200SX / Skyline GTS-T DUMP AN ENGINE FRONT PIPE IN ONE easily. The 2 clamps that come with the 6 meters wrap pack are used to keep the wrap in places after you wrap the pipe, one clamp for each end.
If you need extra clamp, they are AUD$2 each
The wrap is about 2.5 millimeters thick and 1.8 inches wide. It can be used on dump pipes, front pipes, exhaust turbo manifold, air intake piping and also intercooler piping.
HSD Suspension
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
