so
on the topic of head flow,
take the fastest full trim GTR skyline in the world on radials, would that be keir wilson with an 8.89 at 160 mph, now take the fastest full trim supra in the world on radials, TITAN with a 7.94 at 184MPH, gee there head flow must be huge. check out that MPH.
hmm
yes chris i believe your right, over 2400cc in the drag radial class of HPI is carlos, with a 10.04 at 150 mph with a 2.23 60 foot, that MPH certainly shows the head flow against the next placed car which is a nissan GTST of ryan quinn with a 10.12 at 136mph with a 1.6 sixty foot.
once carlos gets his car off the line i believe it will show how good the head flow on that 2j is when it runs an 8 on radials, even with the subwoofers still in the back of the car.
note this is not a shot at kier or ryan, there cars are amazing machines and have accomplished awesome results.
https://www.sau.com.au/forums/topic/126104-rb-vs-jz-drag-cars/
  • Replies 48
Posted Images
Heh you might as wel throw in "well where the hell was the 2JZ at Bathurst"!!!
Seriously ghetto to compare the two cars, I assume you're up to date with the american 2J scene to know that Titan have got the most developed and expensive cylinder head/engine combos out there. And Keir runs with a stock head/ 260 deg cams. More differences:
Direct port and single port nitrous system vs single fogger on Keir
Automatic vs manual (not a clutchless slider clutch either)
GT55 turbo (1550hp) vs twin 61mm(2x550ps)
VP Import fuel vs C16 (if that)
3.4 vs 3.0 litres
RWD vs 4WD
Endless debate, I love the Titan cars but there are too many differences to put them in the same class. Almost the same as comparing you to Theo Wollet or Mark Jacobson i.e. hey same racing class, they must be on equal footing.
3.4 vs 3.0 litres
RWD vs 4WD
I will add the track preparation to Chris's excellent list of differences between Oz and the US.
:) cheers :glare:
3.4 vs 3.0 litres
RWD vs 4WD
hang on, are we talking about head flow or capacity or turbo size or fuel or 4wd or rwd?
titan runs their equivlient of sport rwd if you read the NHRA sport compact rule book, their rules are the same as the ones we play by, as our rule book is a direct copy of theirs. so is it an even footing, maybe not but they have the same opporunities within the rules. theo runs the same turbo as the titan supra a t88 38gk the supra doesnt run a Gt55, their pro rwd scion and celica run Gt55 according to the titan website
3.4 vs 3.0 litres
RWD vs 4WD
kier uses ELF fuel,
uses 272deg cams
and could possibly get away with cruising the streets of Adelaide if he wanted......id like to see Titan do that!
:yes: cheers :D
Do you mean in the way that Australia has the quickest top doorslammer in the world?
Carlos vs Keir is probably a closer comparison and I think you will see very even times once Carlos gets his car off the line.
hats off to team titan but watch the car leave the line i think theyr using alot of gas and alot of boost. but who cares they have many spares in the transporter and lots of money.
i think any engine has potential if thrown big wads of cash at it
but dont forget the hks gtr that produces big mph without the use of nos
and look at mark ashford 7 second 132ci 4 cyl old skool fj20
faaaarrrk thats alot of gas
i think in outright drag aplications both engines are equal
if your after 600rwhp on a std bottom end the 2jz cant be beaten
like the green subzero supra made 998rwhp
and my skyline made 1068rwhp
you could also put that down to wheelspin but are both 3 litre engines
i think the supra run a 9.2 at that power level ova 150mph
ive run a 9.7 @ 141mph with 597rwhp and no gas as im still getting used to the car
who cares if one head flows better std if the other head could possibly be ported further
at the end of the day the man with the deepest pockets wins
which is definately not me as im a peasant
well i dont know how the veilside 32 fits into this but it has now run 7.6XX on slicks beating it's previous 8 second time on nittos. and when i saw it they were still running what looked like factory nissan coil packs! :whistling:
Actually, good point on Carlos/Hardore(?) Supra, pretty much identical setup to Theo's R32. Pretty close matchup, well as close as it's been so far.
I think Carlos's supra is from Millenium motorsports - are we talking about the purple supra UWU55?
Hardcore did have a 2J supra however that motor broke about a few months back im pretty sure...
Anywho have people forgotten about Mark Jacobson's black R32 GTR thats run a 9.3@145mph on M/T ET Streets with I _think_ ~600rwhp - his car did make close to 1000rwhp at the Gold Coast Autosalon dyno comp with gas however the aforementioned time was run without the assistance of nitrous...
Also I think that we have to be talking about cars that are actually built and run in Australia as the budgets are kind off on par, compared to the sponsorship that the Americans get...
Oh yeah - Jason/SLO32 love your car mate!
Edited by TurbostyleR
Keep going mate - damn site more that 600rwhp....
I think you're wrong again.
Forget budgets - xJZ motors suck - you all know it. So do RB's for that matter.
CA18POWAH!
Well as we are talking Drag cars the titan pro rwd has done 6.4@220mph. But what ever happen to this car 7.1@190mph that would have to be the fastest RB yes\no?
http://www.turbomagazine.com/events/0209tu...s/photo_05.html
I own a GTR but would mind a celica with 2JZ aswell RA22\3 mmm :(
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
